| 7TPorsh |
Jun 25 2012, 03:04 PM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
Over the weeknd I had the car up and I removed some of the heater pieces down under the engine. The PO had removed the blower motor but I had venting hot air up into the engine compartment.
I took out a couple of trapezoidal shaped plates that held the ducting attached to the exchangers. So no the exchangers are there now with no ducting attached to them. I can see the bottom end of the heads, push rod tubes and valve covers. Also now exposed on each side of the fan are square openings that have flappers and puff air. can I drive like this? Do I need to close up those square vents somehow? |
| 7TPorsh |
Jun 25 2012, 03:56 PM
I think I would like to close them since more air is better and i think it may quiet it up a little bit.
Not sure how. JB Weld? or will that fry off. Welded? Is it magnesium? |
7TPorsh Removing Heat from the Car Jun 25 2012, 03:04 PM
GeorgeRud You probably could run that way, though you would ... Jun 25 2012, 03:13 PM
mikey63 My car has no heat, everything has been removed. T... Jun 25 2012, 03:30 PM
ThePaintedMan As I preface most of my threads... I'm no expe... Jun 25 2012, 07:36 PM
ChrisNPDrider :agree:
with my stock 1.7 TIV running D-JET I hav... Jun 26 2012, 09:21 AM
r_towle mice Jun 26 2012, 09:24 AM
ape914 you NEED to run cool air thru the heater exchanger... Jun 26 2012, 10:57 AM
rhodyguy i would reinstall the l&r warm air guides. the... Jun 26 2012, 10:58 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 08:34 PM |
