| r_towle |
May 28 2004, 07:30 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Hi,
72 1.7 liter DJet Timing set, dwell set, new plug, points and condensor. Valves just re-adjusted and checked again. It backfires through the throttle body... Low power, then surges as if it cleared its throught the backfiring again..... HELP Suggestions needed Rich |
| mike_the_man |
May 31 2004, 04:33 PM
I like stuff! ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
Could be the trigger points. There's no good way to test them, though. I was having a similar problem, and my heat exchangers were loose. Torqued them all to 16ft/lbs and it fixed it right up. Have you checked the plugs? It could be running lean or rich. I can never remember which one it is that makes it backfire.
Good luck, |
r_towle Backfiring problem May 28 2004, 07:30 PM
vsg914 Did you set the timing before setting the dwell? May 28 2004, 07:34 PM
r_towle valves, dwell, timing in that order, always
Rich May 28 2004, 07:39 PM
vsg914 OK, just checking. Ya never know! Did this jus... May 28 2004, 07:47 PM
r_towle did it last year, tuned it up and it went away....... May 28 2004, 07:49 PM
vsg914 Well, sometimes it just don't make any sense, ... May 28 2004, 08:02 PM
Bullet I always though that a backfire was cuased by the ... May 31 2004, 06:12 PM
efrenv Had the same symptoms with my car. Adjusted valves... May 31 2004, 11:25 PM
Toast ![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 05:32 AM |
