| Mr.242 |
Jun 23 2012, 09:11 AM
May your glass be smaller so it's always FULL! ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
So I got the car running and doing the fine adjustments. First the headlight buckets were set at 180 degrees wrong. Off put the headlights up and on put them down. Got that fixed ASAP.
Then I came to the issue of that headlights on do not illuminate on low beam. I traced it to the high beam/flasher switch and it's sensitivity. If I wiggle it around I can get them to illuminate, but must hold it in the correct position. So obviously a contact issue. High Beams work great, just flip it forward and BAM there is light. Left turn position does not cancel, but flashes. So need to figure that as well. Before I dive into this; What am I looking at and what are my options? I've searched the prior posts and didn't find anything directly related to SIX assemblies. Thought maybe someone could help who's been here before. Thanks in advance. |
| rhodyguy |
Jun 26 2012, 10:45 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
tech tip 658 (AA)"if the turn signals do not cancel, you have one of 2 problems: the steering wheel horn contact rim or steering wheel is on upside down; or, the two canceling fingers in the turn signal switch are broken. the later entails replacement of the switch.".
check the wheel first i guess. did the cancel work when you bought the car? i hope for your sake it's the wheel. k |
Mr.242 914/6 signal switch issues/headlight issues Jun 23 2012, 09:11 AM
Mr.242 :bump:
No advice anywhere? Anyone have some pi... Jun 26 2012, 08:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 12:17 AM |
