| type47 |
Jun 6 2012, 06:10 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
After track sessions this past weekend, oil temps as indicated by a dipstick thermometer (Mainely Custom item) indicated temps of about 252 F after 20 minute sessions (ambient temps in the 60's). The engine is a Euro D-Jet with 20-50 Brad Penn. The engine that was in the car when I bought it (not the same engine as in the car now) has a sandwich oil cooler adapter and the oil cooler is still mounted on the car and I think I will hook it up again. Two questions; first is the indentification of the outlet and inlet on the adapter; which is which or how do I figure out which one the oil should exit from and which should the oil return. Second, on a radiator style oil cooler, do you hook it up so that oil goes in the "top" and filters/goes down the coils and exits out the bottom connection or goes in the bottom and pressure feeds up the cooler and exits out the top to return? TIA
| type47 |
Jun 14 2012, 08:18 AM
This morning I removed the adapter from the engine that was in the car when I bought it and identified it as (possibly) an Earls sandwich adapter with thermostat.
![]() If you recognize it as something else, please let me know. Before I removed it, I tried to determine the tightening torque and got between 25 and 30 ft lbs. A little ball, spring and "stay" (for lack of better description) was lying in the groove and looks like it came out of the filter stand. Any ideas what caused the ball and spring to be pushed out of the stand? I'm trying to determine the inlet and outlet connections of the oil cooler. The cooler looks like this Hayden but is about 13"x5.25" ![]() the cooler is mounted such that the inlet and outlets are pointed upward, that is, the cooler lines are connected above the cooler (cooler is mounted inverse from as shown in pic). Best I can figure is it doesn't matter which is inlet and outlet |
| ChrisFoley |
Jun 15 2012, 08:14 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,032 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
| bdstone914 |
Jun 15 2012, 10:10 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,397 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
A little ball, spring and "stay" (for lack of better description) was lying in the groove and looks like it came out of the filter stand. Without that ball check valve in place you were getting zero oil filtration. Sorry Chris that is wrong. The ball and spring bypasses oil from one side of the adapter bypassing the cooler , not the filter. You will have very little oil cooling but the oil has to go through the adapter and or cooler to get to the filter to get back into the engine. If you are referring to the ball and spring in the oil filter head then you will have both reduced filtration, oil flow to the engine and major oil pressure loss. Bruce |
| ChrisFoley |
Jun 27 2012, 08:31 AM
Sorry Chris that is wrong. You're sure Bruce? (IMG:style_emoticons/default/dry.gif) The thermostatic valve in the sandwich plate doesn't need a ball as part of the assembly. I just took these out of a filter bracket. Looks just like the pcs shown above. ![]() |
type47 sandwich oil cooler adapter and oil cooler questions Jun 6 2012, 06:10 AM
pcar916 My sandwich adapter has an arrow cast into it... Jun 6 2012, 07:22 AM
type47
Note: My sandwich adapter (PermaCool) raises my o... Jun 6 2012, 07:33 AM
type47
A little ball, spring and "stay" (for... Jun 15 2012, 07:49 PM
bdstone914 Ok,
This is one where I have some experience. I wo... Jun 15 2012, 10:03 PM
bdstone914
This morning I removed the adapter from the engin... Jun 15 2012, 10:15 PM
pcar916 From the oil filter's perspective oil will flo... Jun 14 2012, 04:19 PM
tomeric914 That ball, cup and spring are the oil filter bypas... Jun 14 2012, 07:25 PM
pcar916
It's in a thread I contributed to on oil cool... Jun 15 2012, 07:54 AM
Racer Chris
I removed my spring, punched out an aluminum plug... Jun 15 2012, 08:10 AM
type47 revisiting this thread. the system leaks badly. I ... Jun 27 2012, 08:08 AM
pcar916 My PermaCool sandwich plate has a ball. Frankly I... Jun 27 2012, 09:01 AM
type47 I went out to confirm that the ball, spring and th... Jun 27 2012, 12:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th October 2026 - 07:18 PM |
