| type47 |
Jun 6 2012, 06:10 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
After track sessions this past weekend, oil temps as indicated by a dipstick thermometer (Mainely Custom item) indicated temps of about 252 F after 20 minute sessions (ambient temps in the 60's). The engine is a Euro D-Jet with 20-50 Brad Penn. The engine that was in the car when I bought it (not the same engine as in the car now) has a sandwich oil cooler adapter and the oil cooler is still mounted on the car and I think I will hook it up again. Two questions; first is the indentification of the outlet and inlet on the adapter; which is which or how do I figure out which one the oil should exit from and which should the oil return. Second, on a radiator style oil cooler, do you hook it up so that oil goes in the "top" and filters/goes down the coils and exits out the bottom connection or goes in the bottom and pressure feeds up the cooler and exits out the top to return? TIA
| type47 |
Jun 27 2012, 12:12 PM
I went out to confirm that the ball, spring and the round thing I found in the adapter were in fact from the oil filter stand. Sure enough, they came from the oil filter stand. If you have interest in the o-ring, I was told that Earls is now owned by Holley in CA; I googled and found a catalog and the o-ring size was listed in the info about the adapter
http://www.holley.com/EarlsCatalog/Catalog.asp?pageNumber=86 Found the o-ring in the McMaster-Carr catalog and ordered; will get a package of 10 for $10.51; will install Fri in hopes of results of no drip.... Thanks Root..... |
type47 sandwich oil cooler adapter and oil cooler questions Jun 6 2012, 06:10 AM
pcar916 My sandwich adapter has an arrow cast into it... Jun 6 2012, 07:22 AM
type47
Note: My sandwich adapter (PermaCool) raises my o... Jun 6 2012, 07:33 AM
type47 This morning I removed the adapter from the engine... Jun 14 2012, 08:18 AM
Racer Chris
A little ball, spring and "stay" (for ... Jun 15 2012, 08:14 AM
type47
A little ball, spring and "stay" (for... Jun 15 2012, 07:49 PM
bdstone914 Ok,
This is one where I have some experience. I wo... Jun 15 2012, 10:03 PM
bdstone914
A little ball, spring and "stay" (for... Jun 15 2012, 10:10 PM
Racer Chris
Sorry Chris that is wrong.
You're sure Bruce... Jun 27 2012, 08:31 AM
bdstone914
This morning I removed the adapter from the engin... Jun 15 2012, 10:15 PM
pcar916 From the oil filter's perspective oil will flo... Jun 14 2012, 04:19 PM
tomeric914 That ball, cup and spring are the oil filter bypas... Jun 14 2012, 07:25 PM
pcar916
It's in a thread I contributed to on oil cool... Jun 15 2012, 07:54 AM
Racer Chris
I removed my spring, punched out an aluminum plug... Jun 15 2012, 08:10 AM
type47 revisiting this thread. the system leaks badly. I ... Jun 27 2012, 08:08 AM
pcar916 My PermaCool sandwich plate has a ball. Frankly I... Jun 27 2012, 09:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th October 2026 - 07:18 PM |
