> Will it be done before Parade?, Oil cooler installation
Dave_Darling
post Jun 28 2012, 12:15 AM
914 Idiot
Since I'll be driving the 914 through a desert in July, I figure having an external oil cooler might be a good idea. I bought a cooler, thermostat, sandwich plate, and some fittings from Earl's quite a few years back. I don't have any lines, a way to mount the cooler, or a fan.
I wonder if I'll get the install done before the trip? If I do, it'll be close. I have a lot of other obligations which will keep me out of the garage for most days and evenings...
I intend to get the cooler mounted under the rear trunk floor, locate and fasten in the thermostat, add the sandwich plate, then hook it all together with rubber lines. Then I can remove the lines and measure them, so I can get better lines in the correct lengths.
The rubber lines (fuel rated, so hopefully OK with oil) may actually be used as a short-term solution, but I don't expect them to last very long.
I also have to figure out where to get the oil lines and a fan. Hopefully locally, so I don't have to pay for express shipping...
--DD
ChrisFoley
post Jun 28 2012, 06:35 AM
I am Tangerine Racing
QUOTE(Dave_Darling @ Jun 28 2012, 01:15 AM) *
They'l last only as long as it takes for the oil to get hot, the hose to develop an aneurism and pop, spraying oil all over the underside of the car, leaving you stranded on the side of the road.
Fuel hose isn't rated for the pressures an oil system may develop, and I'm sure it isn't rated for pressure at elevated temperatures.
Dave_Darling   Will it be done before Parade?   Jun 28 2012, 12:15 AM
type47   Which Earls adapter did you get? I'm working o...   Jun 28 2012, 04:01 AM
ape914   Which Earls adapter did you get? I'm working ...   Jul 4 2012, 11:09 AM
Racer Chris   The rubber lines (fuel rated, so hopefully OK wit...   Jun 28 2012, 06:35 AM
ThePaintedMan   All I know is cars that leak oil are usually the o...   Jun 28 2012, 06:56 AM
Bartlett 914   I installed a cooler in my car recently. It still ...   Jun 28 2012, 08:42 AM
Dave_Darling   Ah, but these hoses were not supplied with the coo...   Jun 28 2012, 09:20 AM
Randal   Ah, but these hoses were not supplied with the co...   Jun 30 2012, 04:46 PM
McMark   SummitRacing.com ships REALLY fast with just groun...   Jun 28 2012, 09:29 AM
monkeyboy   SummitRacing.com ships REALLY fast with just grou...   Jun 28 2012, 09:34 AM
r_towle   you wont get it done...bring it to Mark :)   Jun 28 2012, 09:46 AM
SirAndy   you wont get it done...bring it to Mark :) :agr...   Jun 28 2012, 11:18 AM
Dave_Darling   The transportation up to Sonoma and back is a bit ...   Jun 28 2012, 05:03 PM
r_towle   The transportation up to Sonoma and back is a bit...   Jun 28 2012, 07:56 PM
Black22   I installed a Bugpack Mesa 72 plate oil cooler w/ ...   Jun 28 2012, 05:38 PM
wndsrfr   Dave--I'm reminded of a small instruction shee...   Jun 28 2012, 08:14 PM
SirAndy   "NOTE: Assembly of bicycle require great peac...   Jun 28 2012, 10:10 PM
GeorgeRud   I imagine that the desert would be quite hot to tr...   Jun 28 2012, 09:39 PM
bdstone914   Chris is 100% right about not using fuel line. I ...   Jun 28 2012, 09:44 PM
Dave_Darling   My car's oil has gotten hot enough climbing th...   Jun 29 2012, 12:56 AM
ClayPerrine   Dave, Just do it... quit kvetching about it. I h...   Jun 29 2012, 11:15 AM
Dave_Darling   You've seen it before, at the last DFW Parade...   Jun 29 2012, 03:08 PM
smj   Urm. I need to get an oil temp gauge hooked up in ...   Jun 29 2012, 04:08 PM
76-914   Hey Dave, :ttiwwp:   Jun 30 2012, 10:09 AM
McMark   Steve, one thing to consider is that a lower HP mo...   Jun 30 2012, 10:25 AM
smj   Steve, one thing to consider is that a lower HP m...   Jul 1 2012, 01:50 AM
RobW   Good luck Dave. I don't want to see the CRX au...   Jun 30 2012, 03:11 PM
Dave_Darling   I went over to the Royal Brass (that's their w...   Jul 1 2012, 12:09 AM
Randal   I went over to the Royal Brass (that's their ...   Jul 1 2012, 07:37 AM
Dave_Darling   Got the cooler and t-stat mounted tonight. I...   Jul 2 2012, 01:18 AM
Dave_Darling   Crap! I need different lines than I bought. ...   Jul 2 2012, 10:35 PM
wndsrfr   Crap! I need different lines than I bought. ...   Jul 3 2012, 03:10 PM
McMark   Sounds like pretty much every oil cooler installat...   Jul 2 2012, 11:53 PM
Dave_Darling   I got a bunch more stuff at noon. Tonight, it...   Jul 3 2012, 03:16 PM
ape914   one thing on my car, i deleted the oil thermostat ...   Jul 4 2012, 11:16 AM
Dave_Darling   Ugh. This thermostat is gonna kill me yet! S...   Jul 4 2012, 11:46 PM
Bartlett 914   Ugh. This thermostat is gonna kill me yet! ...   Jul 5 2012, 10:02 AM
Dave_Darling   So, the definitive answer to the question I posed ...   Jul 6 2012, 10:31 PM
r_towle   I am impressed... Are the fan and thermostat moun...   Jul 7 2012, 06:24 AM
Dave_Darling   They are mounted together, but not well. (More zi...   Jul 7 2012, 10:27 PM
JamesM   Dave, If you, or anyone else comming out to parad...   Jul 8 2012, 07:21 AM
r_towle   They are mounted together, but not well. (More z...   Jul 8 2012, 02:38 PM
Dave_Darling   It never even got to 250, which is an improvement ...   Jul 8 2012, 05:21 PM
ConeDodger   Are you all checked in Dave? Kick some 'Tech Q...   Jul 8 2012, 05:32 PM
Dave_Darling   I'm hoping to do just that! My record so ...   Jul 8 2012, 11:22 PM
JamesM   Dave, Just got your message about the tranny didn...   Jul 9 2012, 12:29 AM
Dave_Darling   I didn't make the autoX. In fact, the wife an...   Jul 15 2012, 07:10 PM
Randal   I didn't make the autoX. In fact, the wife a...   Jul 15 2012, 07:22 PM
- Lo-Fi Version Time is now: 1st May 2026 - 02:44 PM
