| Dave_Darling |
Jun 28 2012, 12:15 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Since I'll be driving the 914 through a desert in July, I figure having an external oil cooler might be a good idea. I bought a cooler, thermostat, sandwich plate, and some fittings from Earl's quite a few years back. I don't have any lines, a way to mount the cooler, or a fan.
I wonder if I'll get the install done before the trip? If I do, it'll be close. I have a lot of other obligations which will keep me out of the garage for most days and evenings... I intend to get the cooler mounted under the rear trunk floor, locate and fasten in the thermostat, add the sandwich plate, then hook it all together with rubber lines. Then I can remove the lines and measure them, so I can get better lines in the correct lengths. The rubber lines (fuel rated, so hopefully OK with oil) may actually be used as a short-term solution, but I don't expect them to last very long. I also have to figure out where to get the oil lines and a fan. Hopefully locally, so I don't have to pay for express shipping... --DD |
| ClayPerrine |
Jun 29 2012, 11:15 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Dave,
Just do it... quit kvetching about it. I have been prepping Betty's car for Parade, and in the past few weeks, I have: Installed new carpet. Installed new door boxes. Changed the clutch. Changed the shocks and springs (Did the fronts last night after work.) Replaced all 4 tires. Replaced the brake pads and flushed the brake system. Replaced one Fuchs rim after it cracked at an AX. Replaced the front wheel bearings. Adjusted the valves. Fixed the broken exhaust hanger. Installed new seat belts. Installed the wiring for the radar detector. Chased down an intermittent cut out issue. To go: Change the oil cooler seals and the oil Saturday morning. All this while working 50 to 60 hour weeks, and finishing my Black Belt. Oh..and it will be good to finally see YOUR 914 in person. |
Dave_Darling Will it be done before Parade? Jun 28 2012, 12:15 AM
type47 Which Earls adapter did you get? I'm working o... Jun 28 2012, 04:01 AM
ape914
Which Earls adapter did you get? I'm working ... Jul 4 2012, 11:09 AM
Racer Chris
The rubber lines (fuel rated, so hopefully OK wit... Jun 28 2012, 06:35 AM
ThePaintedMan All I know is cars that leak oil are usually the o... Jun 28 2012, 06:56 AM
Bartlett 914 I installed a cooler in my car recently. It still ... Jun 28 2012, 08:42 AM
Dave_Darling Ah, but these hoses were not supplied with the coo... Jun 28 2012, 09:20 AM
Randal
Ah, but these hoses were not supplied with the co... Jun 30 2012, 04:46 PM
McMark SummitRacing.com ships REALLY fast with just groun... Jun 28 2012, 09:29 AM
monkeyboy
SummitRacing.com ships REALLY fast with just grou... Jun 28 2012, 09:34 AM
r_towle you wont get it done...bring it to Mark :) Jun 28 2012, 09:46 AM
:agr... Jun 28 2012, 11:18 AM
Dave_Darling The transportation up to Sonoma and back is a bit ... Jun 28 2012, 05:03 PM
r_towle
The transportation up to Sonoma and back is a bit... Jun 28 2012, 07:56 PM
Black22 I installed a Bugpack Mesa 72 plate oil cooler w/ ... Jun 28 2012, 05:38 PM
wndsrfr Dave--I'm reminded of a small instruction shee... Jun 28 2012, 08:14 PM
SirAndy "NOTE: Assembly of bicycle require great peac... Jun 28 2012, 10:10 PM
GeorgeRud I imagine that the desert would be quite hot to tr... Jun 28 2012, 09:39 PM
bdstone914 Chris is 100% right about not using fuel line. I ... Jun 28 2012, 09:44 PM
Dave_Darling My car's oil has gotten hot enough climbing th... Jun 29 2012, 12:56 AM
Dave_Darling You've seen it before, at the last DFW Parade... Jun 29 2012, 03:08 PM
smj Urm. I need to get an oil temp gauge hooked up in ... Jun 29 2012, 04:08 PM
76-914 Hey Dave, :ttiwwp: Jun 30 2012, 10:09 AM
McMark Steve, one thing to consider is that a lower HP mo... Jun 30 2012, 10:25 AM
smj
Steve, one thing to consider is that a lower HP m... Jul 1 2012, 01:50 AM
RobW Good luck Dave. I don't want to see the CRX au... Jun 30 2012, 03:11 PM
Dave_Darling I went over to the Royal Brass (that's their w... Jul 1 2012, 12:09 AM
Randal
I went over to the Royal Brass (that's their ... Jul 1 2012, 07:37 AM
Dave_Darling Got the cooler and t-stat mounted tonight. I... Jul 2 2012, 01:18 AM
Dave_Darling Crap! I need different lines than I bought. ... Jul 2 2012, 10:35 PM
wndsrfr
Crap! I need different lines than I bought. ... Jul 3 2012, 03:10 PM
McMark Sounds like pretty much every oil cooler installat... Jul 2 2012, 11:53 PM
Dave_Darling I got a bunch more stuff at noon. Tonight, it... Jul 3 2012, 03:16 PM
ape914 one thing on my car, i deleted the oil thermostat ... Jul 4 2012, 11:16 AM
Dave_Darling Ugh. This thermostat is gonna kill me yet! S... Jul 4 2012, 11:46 PM
Bartlett 914
Ugh. This thermostat is gonna kill me yet! ... Jul 5 2012, 10:02 AM
Dave_Darling So, the definitive answer to the question I posed ... Jul 6 2012, 10:31 PM
r_towle I am impressed...
Are the fan and thermostat moun... Jul 7 2012, 06:24 AM
Dave_Darling They are mounted together, but not well. (More zi... Jul 7 2012, 10:27 PM
JamesM Dave, If you, or anyone else comming out to parad... Jul 8 2012, 07:21 AM
r_towle
They are mounted together, but not well. (More z... Jul 8 2012, 02:38 PM
Dave_Darling It never even got to 250, which is an improvement ... Jul 8 2012, 05:21 PM
ConeDodger Are you all checked in Dave? Kick some 'Tech Q... Jul 8 2012, 05:32 PM
Dave_Darling I'm hoping to do just that! My record so ... Jul 8 2012, 11:22 PM
JamesM Dave, Just got your message about the tranny didn... Jul 9 2012, 12:29 AM
Dave_Darling I didn't make the autoX. In fact, the wife an... Jul 15 2012, 07:10 PM
Randal
I didn't make the autoX. In fact, the wife a... Jul 15 2012, 07:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 02:43 PM |
