| Dave_Darling |
Jun 28 2012, 12:15 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Since I'll be driving the 914 through a desert in July, I figure having an external oil cooler might be a good idea. I bought a cooler, thermostat, sandwich plate, and some fittings from Earl's quite a few years back. I don't have any lines, a way to mount the cooler, or a fan.
I wonder if I'll get the install done before the trip? If I do, it'll be close. I have a lot of other obligations which will keep me out of the garage for most days and evenings... I intend to get the cooler mounted under the rear trunk floor, locate and fasten in the thermostat, add the sandwich plate, then hook it all together with rubber lines. Then I can remove the lines and measure them, so I can get better lines in the correct lengths. The rubber lines (fuel rated, so hopefully OK with oil) may actually be used as a short-term solution, but I don't expect them to last very long. I also have to figure out where to get the oil lines and a fan. Hopefully locally, so I don't have to pay for express shipping... --DD |
| Dave_Darling |
Jun 28 2012, 09:20 AM
Ah, but these hoses were not supplied with the cooler!
I guess that means I really have to find a local source of oil-rated hose, then. Any suggestions? --DD |
| Randal |
Jun 30 2012, 04:46 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Ah, but these hoses were not supplied with the cooler! I guess that means I really have to find a local source of oil-rated hose, then. Any suggestions? --DD Dave, any hydraulic supply house (like for tractors) will have super strong rubber hose that is rated for high pressure hydraulic lines running tractor accessories. Oil pressure is low compared to hydraulic pressure lines. Also the hose is industrial, so wear resistent. I had these lines on my 2.0 liter's external oil system (radiator and fan tied to the engine cover) before I went with a front mounted setup. They will also make up all the fittings you need, many times less expensive than using Earl's. All you need to do it tell them the lengths and the type of fittings and when you arrive they will be done. It might make sense to go to one of the supply houses as some of the fittings might be heaver than you want so check them out first. There is one place on 10th Street in San Jose: http://www.rbisj.com/ |
Dave_Darling Will it be done before Parade? Jun 28 2012, 12:15 AM
type47 Which Earls adapter did you get? I'm working o... Jun 28 2012, 04:01 AM
ape914
Which Earls adapter did you get? I'm working ... Jul 4 2012, 11:09 AM
Racer Chris
The rubber lines (fuel rated, so hopefully OK wit... Jun 28 2012, 06:35 AM
ThePaintedMan All I know is cars that leak oil are usually the o... Jun 28 2012, 06:56 AM
Bartlett 914 I installed a cooler in my car recently. It still ... Jun 28 2012, 08:42 AM
McMark SummitRacing.com ships REALLY fast with just groun... Jun 28 2012, 09:29 AM
monkeyboy
SummitRacing.com ships REALLY fast with just grou... Jun 28 2012, 09:34 AM
r_towle you wont get it done...bring it to Mark :) Jun 28 2012, 09:46 AM
:agr... Jun 28 2012, 11:18 AM
Dave_Darling The transportation up to Sonoma and back is a bit ... Jun 28 2012, 05:03 PM
r_towle
The transportation up to Sonoma and back is a bit... Jun 28 2012, 07:56 PM
Black22 I installed a Bugpack Mesa 72 plate oil cooler w/ ... Jun 28 2012, 05:38 PM
wndsrfr Dave--I'm reminded of a small instruction shee... Jun 28 2012, 08:14 PM
SirAndy "NOTE: Assembly of bicycle require great peac... Jun 28 2012, 10:10 PM
GeorgeRud I imagine that the desert would be quite hot to tr... Jun 28 2012, 09:39 PM
bdstone914 Chris is 100% right about not using fuel line. I ... Jun 28 2012, 09:44 PM
Dave_Darling My car's oil has gotten hot enough climbing th... Jun 29 2012, 12:56 AM
ClayPerrine Dave,
Just do it... quit kvetching about it. I h... Jun 29 2012, 11:15 AM
Dave_Darling You've seen it before, at the last DFW Parade... Jun 29 2012, 03:08 PM
smj Urm. I need to get an oil temp gauge hooked up in ... Jun 29 2012, 04:08 PM
76-914 Hey Dave, :ttiwwp: Jun 30 2012, 10:09 AM
McMark Steve, one thing to consider is that a lower HP mo... Jun 30 2012, 10:25 AM
smj
Steve, one thing to consider is that a lower HP m... Jul 1 2012, 01:50 AM
RobW Good luck Dave. I don't want to see the CRX au... Jun 30 2012, 03:11 PM
Dave_Darling I went over to the Royal Brass (that's their w... Jul 1 2012, 12:09 AM
Randal
I went over to the Royal Brass (that's their ... Jul 1 2012, 07:37 AM
Dave_Darling Got the cooler and t-stat mounted tonight. I... Jul 2 2012, 01:18 AM
Dave_Darling Crap! I need different lines than I bought. ... Jul 2 2012, 10:35 PM
wndsrfr
Crap! I need different lines than I bought. ... Jul 3 2012, 03:10 PM
McMark Sounds like pretty much every oil cooler installat... Jul 2 2012, 11:53 PM
Dave_Darling I got a bunch more stuff at noon. Tonight, it... Jul 3 2012, 03:16 PM
ape914 one thing on my car, i deleted the oil thermostat ... Jul 4 2012, 11:16 AM
Dave_Darling Ugh. This thermostat is gonna kill me yet! S... Jul 4 2012, 11:46 PM
Bartlett 914
Ugh. This thermostat is gonna kill me yet! ... Jul 5 2012, 10:02 AM
Dave_Darling So, the definitive answer to the question I posed ... Jul 6 2012, 10:31 PM
r_towle I am impressed...
Are the fan and thermostat moun... Jul 7 2012, 06:24 AM
Dave_Darling They are mounted together, but not well. (More zi... Jul 7 2012, 10:27 PM
JamesM Dave, If you, or anyone else comming out to parad... Jul 8 2012, 07:21 AM
r_towle
They are mounted together, but not well. (More z... Jul 8 2012, 02:38 PM
Dave_Darling It never even got to 250, which is an improvement ... Jul 8 2012, 05:21 PM
ConeDodger Are you all checked in Dave? Kick some 'Tech Q... Jul 8 2012, 05:32 PM
Dave_Darling I'm hoping to do just that! My record so ... Jul 8 2012, 11:22 PM
JamesM Dave, Just got your message about the tranny didn... Jul 9 2012, 12:29 AM
Dave_Darling I didn't make the autoX. In fact, the wife an... Jul 15 2012, 07:10 PM
Randal
I didn't make the autoX. In fact, the wife a... Jul 15 2012, 07:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 02:43 PM |
