> Will it be done before Parade?, Oil cooler installation
Dave_Darling
post Jun 28 2012, 12:15 AM
914 Idiot
Since I'll be driving the 914 through a desert in July, I figure having an external oil cooler might be a good idea. I bought a cooler, thermostat, sandwich plate, and some fittings from Earl's quite a few years back. I don't have any lines, a way to mount the cooler, or a fan.
I wonder if I'll get the install done before the trip? If I do, it'll be close. I have a lot of other obligations which will keep me out of the garage for most days and evenings...
I intend to get the cooler mounted under the rear trunk floor, locate and fasten in the thermostat, add the sandwich plate, then hook it all together with rubber lines. Then I can remove the lines and measure them, so I can get better lines in the correct lengths.
The rubber lines (fuel rated, so hopefully OK with oil) may actually be used as a short-term solution, but I don't expect them to last very long.
I also have to figure out where to get the oil lines and a fan. Hopefully locally, so I don't have to pay for express shipping...
--DD
McMark
post Jun 30 2012, 10:25 AM
914 Freak!
Steve, one thing to consider is that a lower HP motor pulling up a hill is working harder (and generating more heat).
Go, Dave! Go!
smj
post Jul 1 2012, 01:50 AM
"Dude, Steve from Berkeley."
QUOTE(McMark @ Jun 30 2012, 08:25 AM) *
Thanks Mark - have the 911 oil temp/pressure gauge, just got to get it hooked up. Then look for a 105+ day to take the -6 over the hills and run up Mt. Diablo or something. Then I can just worry about 5,000+ ft of altitude, which of course will require a trip up to Lake Tahoe to test. Safety First! (IMG:style_emoticons/default/wink.gif)
Thanks for the minor thread-jaak Dave! I'm taking notes about getting oil lines from hydaulic shops. If I hit the trifecta, maybe I'll find one that'll also repair my stupid Sears floor jack. (IMG:style_emoticons/default/barf.gif)
Dave_Darling   Will it be done before Parade?   Jun 28 2012, 12:15 AM
type47   Which Earls adapter did you get? I'm working o...   Jun 28 2012, 04:01 AM
ape914   Which Earls adapter did you get? I'm working ...   Jul 4 2012, 11:09 AM
Racer Chris   The rubber lines (fuel rated, so hopefully OK wit...   Jun 28 2012, 06:35 AM
ThePaintedMan   All I know is cars that leak oil are usually the o...   Jun 28 2012, 06:56 AM
Bartlett 914   I installed a cooler in my car recently. It still ...   Jun 28 2012, 08:42 AM
Dave_Darling   Ah, but these hoses were not supplied with the coo...   Jun 28 2012, 09:20 AM
Randal   Ah, but these hoses were not supplied with the co...   Jun 30 2012, 04:46 PM
McMark   SummitRacing.com ships REALLY fast with just groun...   Jun 28 2012, 09:29 AM
monkeyboy   SummitRacing.com ships REALLY fast with just grou...   Jun 28 2012, 09:34 AM
r_towle   you wont get it done...bring it to Mark :)   Jun 28 2012, 09:46 AM
SirAndy   you wont get it done...bring it to Mark :) :agr...   Jun 28 2012, 11:18 AM
Dave_Darling   The transportation up to Sonoma and back is a bit ...   Jun 28 2012, 05:03 PM
r_towle   The transportation up to Sonoma and back is a bit...   Jun 28 2012, 07:56 PM
Black22   I installed a Bugpack Mesa 72 plate oil cooler w/ ...   Jun 28 2012, 05:38 PM
wndsrfr   Dave--I'm reminded of a small instruction shee...   Jun 28 2012, 08:14 PM
SirAndy   "NOTE: Assembly of bicycle require great peac...   Jun 28 2012, 10:10 PM
GeorgeRud   I imagine that the desert would be quite hot to tr...   Jun 28 2012, 09:39 PM
bdstone914   Chris is 100% right about not using fuel line. I ...   Jun 28 2012, 09:44 PM
Dave_Darling   My car's oil has gotten hot enough climbing th...   Jun 29 2012, 12:56 AM
ClayPerrine   Dave, Just do it... quit kvetching about it. I h...   Jun 29 2012, 11:15 AM
Dave_Darling   You've seen it before, at the last DFW Parade...   Jun 29 2012, 03:08 PM
smj   Urm. I need to get an oil temp gauge hooked up in ...   Jun 29 2012, 04:08 PM
76-914   Hey Dave, :ttiwwp:   Jun 30 2012, 10:09 AM
McMark   Steve, one thing to consider is that a lower HP mo...   Jun 30 2012, 10:25 AM
smj   Steve, one thing to consider is that a lower HP m...   Jul 1 2012, 01:50 AM
RobW   Good luck Dave. I don't want to see the CRX au...   Jun 30 2012, 03:11 PM
Dave_Darling   I went over to the Royal Brass (that's their w...   Jul 1 2012, 12:09 AM
Randal   I went over to the Royal Brass (that's their ...   Jul 1 2012, 07:37 AM
Dave_Darling   Got the cooler and t-stat mounted tonight. I...   Jul 2 2012, 01:18 AM
Dave_Darling   Crap! I need different lines than I bought. ...   Jul 2 2012, 10:35 PM
wndsrfr   Crap! I need different lines than I bought. ...   Jul 3 2012, 03:10 PM
McMark   Sounds like pretty much every oil cooler installat...   Jul 2 2012, 11:53 PM
Dave_Darling   I got a bunch more stuff at noon. Tonight, it...   Jul 3 2012, 03:16 PM
ape914   one thing on my car, i deleted the oil thermostat ...   Jul 4 2012, 11:16 AM
Dave_Darling   Ugh. This thermostat is gonna kill me yet! S...   Jul 4 2012, 11:46 PM
Bartlett 914   Ugh. This thermostat is gonna kill me yet! ...   Jul 5 2012, 10:02 AM
Dave_Darling   So, the definitive answer to the question I posed ...   Jul 6 2012, 10:31 PM
r_towle   I am impressed... Are the fan and thermostat moun...   Jul 7 2012, 06:24 AM
Dave_Darling   They are mounted together, but not well. (More zi...   Jul 7 2012, 10:27 PM
JamesM   Dave, If you, or anyone else comming out to parad...   Jul 8 2012, 07:21 AM
r_towle   They are mounted together, but not well. (More z...   Jul 8 2012, 02:38 PM
Dave_Darling   It never even got to 250, which is an improvement ...   Jul 8 2012, 05:21 PM
ConeDodger   Are you all checked in Dave? Kick some 'Tech Q...   Jul 8 2012, 05:32 PM
Dave_Darling   I'm hoping to do just that! My record so ...   Jul 8 2012, 11:22 PM
JamesM   Dave, Just got your message about the tranny didn...   Jul 9 2012, 12:29 AM
Dave_Darling   I didn't make the autoX. In fact, the wife an...   Jul 15 2012, 07:10 PM
Randal   I didn't make the autoX. In fact, the wife a...   Jul 15 2012, 07:22 PM
- Lo-Fi Version Time is now: 1st May 2026 - 02:44 PM
