> Backfiring problem
r_towle
post May 28 2004, 07:30 PM
Custom Member
Hi,
72 1.7 liter
DJet
Timing set, dwell set, new plug, points and condensor.
Valves just re-adjusted and checked again.
It backfires through the throttle body...
Low power, then surges as if it cleared its throught
the backfiring again.....
HELP
Suggestions needed
Rich
Toast
post Jun 1 2004, 12:12 PM
QUOTE(mike_the_man @ May 31 2004, 02:33 PM)
It could be running lean or rich.  I can never remember which one it is that makes it backfire.
Rich
Bullett.. I always though that a backfire was cuased by the mixture in the combustion chaber being fired when the valves were open. Which would be a timming issue,
Thats because it is running too rich and extra gas is getting through that is burning off durring the spark.
r_towle   Backfiring problem   May 28 2004, 07:30 PM
vsg914   Did you set the timing before setting the dwell?   May 28 2004, 07:34 PM
r_towle   valves, dwell, timing in that order, always Rich   May 28 2004, 07:39 PM
vsg914   OK, just checking. Ya never know! Did this jus...   May 28 2004, 07:47 PM
r_towle   did it last year, tuned it up and it went away.......   May 28 2004, 07:49 PM
vsg914   Well, sometimes it just don't make any sense, ...   May 28 2004, 08:02 PM
mike_the_man   Could be the trigger points. There's no good ...   May 31 2004, 04:33 PM
Bullet   I always though that a backfire was cuased by the ...   May 31 2004, 06:12 PM
efrenv   Had the same symptoms with my car. Adjusted valves...   May 31 2004, 11:25 PM
Toast
- Lo-Fi Version Time is now: 3rd March 2026 - 05:33 AM
