| CG-914 |
Jul 2 2012, 09:03 AM
Member ![]() ![]() Group: Members Posts: 327 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Hi everyone,
I have a 74 2.0 with the euro pistons. (Compression 8:1) My question what is the cfm on those? Does anybody maybe has the formula? Thank you! (IMG:style_emoticons/default/pray.gif) |
| CG-914 |
Jul 2 2012, 04:47 PM
I already bought the cam super set, (have it sitting on the table (IMG:style_emoticons/default/evilgrin.gif) ),
but he did not talk to me. They only do that, when you purchase a consultation for $799 or close to that... I just think, that the valve train set up is responsible for a higher rpm and not the bore. But did you (vsg914) got your engine counter balanced? |
CG-914 cfm? Jul 2 2012, 09:03 AM
vsg914 cubic feet per minute? Jul 2 2012, 09:20 AM
CG-914 I guess, the english acronyms are new to me (from ... Jul 2 2012, 09:28 AM
John Jentz
I guess, the english acronyms are new to me (from... Jul 2 2012, 09:37 AM
CG-914 Efective power range on the 9550:
160 cfm heads = ... Jul 2 2012, 09:48 AM
vsg914 OK, 2.1 L is a 2056 (stock stroke and 96 mm piston... Jul 2 2012, 09:59 AM
CG-914 the piston pins are 24mm on my engine?
For 6200 r... Jul 2 2012, 10:01 AM
HAM Inc A stock 2.0 914 intake port flows around 180cfm @.... Jul 2 2012, 11:01 AM
CG-914 96mm bore cylinders and RS+ heads are a dream,
but... Jul 2 2012, 01:37 PM
vsg914 Once you purchase the cam and valve train upgrade,... Jul 2 2012, 01:59 PM
vsg914 I guess he has changed the way he does things. He ... Jul 2 2012, 05:50 PM
CG-914
I guess he has changed the way he does things. He... Jul 2 2012, 05:55 PM
Valy The max RPM is mainly dependent on your valve spri... Jul 2 2012, 10:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th October 2026 - 11:33 PM |
