| Dave_Darling |
Jun 28 2012, 12:15 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Since I'll be driving the 914 through a desert in July, I figure having an external oil cooler might be a good idea. I bought a cooler, thermostat, sandwich plate, and some fittings from Earl's quite a few years back. I don't have any lines, a way to mount the cooler, or a fan.
I wonder if I'll get the install done before the trip? If I do, it'll be close. I have a lot of other obligations which will keep me out of the garage for most days and evenings... I intend to get the cooler mounted under the rear trunk floor, locate and fasten in the thermostat, add the sandwich plate, then hook it all together with rubber lines. Then I can remove the lines and measure them, so I can get better lines in the correct lengths. The rubber lines (fuel rated, so hopefully OK with oil) may actually be used as a short-term solution, but I don't expect them to last very long. I also have to figure out where to get the oil lines and a fan. Hopefully locally, so I don't have to pay for express shipping... --DD |
| Dave_Darling |
Jul 2 2012, 10:35 PM
Crap! I need different lines than I bought. I might be able to make do with some extra 90-degree fittings. Feh. Back to Royal Brass tomorrow.
--DD |
| wndsrfr |
Jul 3 2012, 03:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,461 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
Crap! I need different lines than I bought. I might be able to make do with some extra 90-degree fittings. Feh. Back to Royal Brass tomorrow. --DD "NOTE: Assembly of (insert whatever 914 related thing you're working on) require great peace of mind." Actually, those 90 degree fittings really did save my sanity when I was doing mine...and they're cheap & dependable! |
Dave_Darling Will it be done before Parade? Jun 28 2012, 12:15 AM
type47 Which Earls adapter did you get? I'm working o... Jun 28 2012, 04:01 AM
ape914
Which Earls adapter did you get? I'm working ... Jul 4 2012, 11:09 AM
Racer Chris
The rubber lines (fuel rated, so hopefully OK wit... Jun 28 2012, 06:35 AM
ThePaintedMan All I know is cars that leak oil are usually the o... Jun 28 2012, 06:56 AM
Bartlett 914 I installed a cooler in my car recently. It still ... Jun 28 2012, 08:42 AM
Dave_Darling Ah, but these hoses were not supplied with the coo... Jun 28 2012, 09:20 AM
Randal
Ah, but these hoses were not supplied with the co... Jun 30 2012, 04:46 PM
McMark SummitRacing.com ships REALLY fast with just groun... Jun 28 2012, 09:29 AM
monkeyboy
SummitRacing.com ships REALLY fast with just grou... Jun 28 2012, 09:34 AM
r_towle you wont get it done...bring it to Mark :) Jun 28 2012, 09:46 AM
:agr... Jun 28 2012, 11:18 AM
Dave_Darling The transportation up to Sonoma and back is a bit ... Jun 28 2012, 05:03 PM
r_towle
The transportation up to Sonoma and back is a bit... Jun 28 2012, 07:56 PM
Black22 I installed a Bugpack Mesa 72 plate oil cooler w/ ... Jun 28 2012, 05:38 PM
wndsrfr Dave--I'm reminded of a small instruction shee... Jun 28 2012, 08:14 PM
SirAndy "NOTE: Assembly of bicycle require great peac... Jun 28 2012, 10:10 PM
GeorgeRud I imagine that the desert would be quite hot to tr... Jun 28 2012, 09:39 PM
bdstone914 Chris is 100% right about not using fuel line. I ... Jun 28 2012, 09:44 PM
Dave_Darling My car's oil has gotten hot enough climbing th... Jun 29 2012, 12:56 AM
ClayPerrine Dave,
Just do it... quit kvetching about it. I h... Jun 29 2012, 11:15 AM
Dave_Darling You've seen it before, at the last DFW Parade... Jun 29 2012, 03:08 PM
smj Urm. I need to get an oil temp gauge hooked up in ... Jun 29 2012, 04:08 PM
76-914 Hey Dave, :ttiwwp: Jun 30 2012, 10:09 AM
McMark Steve, one thing to consider is that a lower HP mo... Jun 30 2012, 10:25 AM
smj
Steve, one thing to consider is that a lower HP m... Jul 1 2012, 01:50 AM
RobW Good luck Dave. I don't want to see the CRX au... Jun 30 2012, 03:11 PM
Dave_Darling I went over to the Royal Brass (that's their w... Jul 1 2012, 12:09 AM
Randal
I went over to the Royal Brass (that's their ... Jul 1 2012, 07:37 AM
Dave_Darling Got the cooler and t-stat mounted tonight. I... Jul 2 2012, 01:18 AM
McMark Sounds like pretty much every oil cooler installat... Jul 2 2012, 11:53 PM
Dave_Darling I got a bunch more stuff at noon. Tonight, it... Jul 3 2012, 03:16 PM
ape914 one thing on my car, i deleted the oil thermostat ... Jul 4 2012, 11:16 AM
Dave_Darling Ugh. This thermostat is gonna kill me yet! S... Jul 4 2012, 11:46 PM
Bartlett 914
Ugh. This thermostat is gonna kill me yet! ... Jul 5 2012, 10:02 AM
Dave_Darling So, the definitive answer to the question I posed ... Jul 6 2012, 10:31 PM
r_towle I am impressed...
Are the fan and thermostat moun... Jul 7 2012, 06:24 AM
Dave_Darling They are mounted together, but not well. (More zi... Jul 7 2012, 10:27 PM
JamesM Dave, If you, or anyone else comming out to parad... Jul 8 2012, 07:21 AM
r_towle
They are mounted together, but not well. (More z... Jul 8 2012, 02:38 PM
Dave_Darling It never even got to 250, which is an improvement ... Jul 8 2012, 05:21 PM
ConeDodger Are you all checked in Dave? Kick some 'Tech Q... Jul 8 2012, 05:32 PM
Dave_Darling I'm hoping to do just that! My record so ... Jul 8 2012, 11:22 PM
JamesM Dave, Just got your message about the tranny didn... Jul 9 2012, 12:29 AM
Dave_Darling I didn't make the autoX. In fact, the wife an... Jul 15 2012, 07:10 PM
Randal
I didn't make the autoX. In fact, the wife a... Jul 15 2012, 07:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 02:45 PM |
