914-6 air conditioning, Advice on compressor choise |
turboman |
Jul 3 2012, 07:56 AM
Newbie Group: Members Posts: 6 Joined: 22-June 12 From: Montoison France Member No.: 14,589 Region Association: France |
Hi, I am in the process to install an original 914 VPC system in my 914-6.
Like all my projects, I work on a budget. First I bought all the parts about 5 years ago, then I refurbished all parts, (professional cleaning, expansion valve) installed the condenser in the front trunk as designed, temporary installed the evaporator console under the dash, and start the preparation process for the compressor installation. I want the installation to be as close as possible to a factory one. For me, is not an option a compressor under the engine, a serpentine belt or similar. I prefer to work extra time, and reach a perfect end product. I used a double pulley from a 74 911, in order to install the pulley and have space for the dual belts, I have to shave a bit the original engine support and the engine cover (see photo). I fit a 2.2 or 2.4 bracket. So far no problems, the end result looks very nice Now I need to choose the compressor. The York is out of question, due to size and efficiency. My options are a Sanden, a Denso or a Panasonic. Any one fitted with a one groove pulley Not being familiar with the air conditioner compressors, and the way you need to calculate cooling capacity vs cabin volume, I would like to ask help form all of you. 1. Which compressor will suit my needs the best? 2. Which compressor is the smallest one? 3. The best compromise? I will keep all of you posted of the progress on the installation and the need or not of a firewall modification. Thanks Francisco Attached thumbnail(s) Attached image(s) |
pcar916 |
Jul 5 2012, 08:08 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
On running an axle pulley as a power take-off. It's been used on various cars to power the alternators and I don't see any reason it can't be used on the AC as well. I was going to use it that way except that it would have taken up trunk space. The rear trunk space is all I have left in my 914 so I give it up reluctantly. But to make that work...
I would want to design an electric cutoff to disengage the clutch below a certain rpm (to keep flow through the the expansion valve from getting too low) and that would depend on the relative pulley sizes. The only way to keep it running while below that rpm would be a fairly large electric motor and a differential clutch/pulley. That's a lot of weight for a light car, not to mention the complexity, and there's a maintenance cost for the latter that I'm not willing to pay. I haven't jumped in on this but may next year since I have most of the bits. Too many projects to worry about it this summer. Hmmm Ice/water box and a small electric pump for a cool-jacket, or an RV / AC box on the roof!? Wouldn't that be a sight... (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 04:20 AM |
