| ChrisFoley |
May 30 2012, 10:20 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
I'm offering a kit which includes a diaphragm, o-rings and paper gasket, to rebuild D-Jet MPS units.
I already obtained an acceptable quotation on the most challenging component - new stamped beryllium copper diaphragm pieces. The sample I used for CAD was the "triple ripple" shape which I think is the most recent design from Bosch. The mild steel hub pieces will be zinc plated just like oem. We will swage the hubs onto the diaphragms in-house. Your adjusting screws which thread into the diaphragms will be re-used with new o-ring provided in the kit. A new o-ring to seal the housing is also in the kit. A new full load stop screw is the centerpiece of a tuning kit which also includes a special 7mm hollow hex driver and correctly sized flat blade screwdriver. The stop screw has an 8mm hex thru hole instead of the large slot in the originals. Adjustments will be made without removing the stop screw. Someone else might be interested in providing assembly/adjustment services. I could do that too, but we aren't set up for it right now. CAD: ![]() Production pieces: ![]() Edit 12/08/12: Final Production begins soon. Current prices: Diaphragm Kits-$127.95; Tuning Kits-$46.95; Both Kits Together-$166.95. Shipping Included Order from our Whats New Page. |
| pbanders |
Jun 25 2012, 10:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 990 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
Very interesting. I'll order one, soon, and I'll update my page with the info on the kit. I get hits from round the world, from D-Jet owners far outside of the 914 community, so I may be able to drum up considerable interest (e.g. Volvo, M-B, Citroen, etc.). As for calibration, hate to tell you, but using either an LCR meter or a bench tester (like an EFI Associates tester) is the only way I know how to reliably set up an MPS. Too many variables to using a mechanical method (with a vernier depth gauge).
| 914_teener |
Jun 27 2012, 07:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Very interesting. I'll order one, soon, and I'll update my page with the info on the kit. I get hits from round the world, from D-Jet owners far outside of the 914 community, so I may be able to drum up considerable interest (e.g. Volvo, M-B, Citroen, etc.). As for calibration, hate to tell you, but using either an LCR meter or a bench tester (like an EFI Associates tester) is the only way I know how to reliably set up an MPS. Too many variables to using a mechanical method (with a vernier depth gauge). My plan is to install a wide band sensor... so is there anyway to get it close first Chris and then adjust on the road or perhaps on a dyno? Right now I have a rebuilt unit...but I know it is running lean on part to full load. Goal is to change out to the kit and see what happens and then tune to the AFR gauge with the kit. Does this make sense given what Brad has said? |
| scott_in_nh |
Jun 28 2012, 08:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 811 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
Very interesting. I'll order one, soon, and I'll update my page with the info on the kit. I get hits from round the world, from D-Jet owners far outside of the 914 community, so I may be able to drum up considerable interest (e.g. Volvo, M-B, Citroen, etc.). As for calibration, hate to tell you, but using either an LCR meter or a bench tester (like an EFI Associates tester) is the only way I know how to reliably set up an MPS. Too many variables to using a mechanical method (with a vernier depth gauge). My plan is to install a wide band sensor... so is there anyway to get it close first Chris and then adjust on the road or perhaps on a dyno? Right now I have a rebuilt unit...but I know it is running lean on part to full load. Goal is to change out to the kit and see what happens and then tune to the AFR gauge with the kit. Does this make sense given what Brad has said? Brads writing on the subject has been a great help to me in getting my car running well (thanks Brad!)! I have access to a LCR and setup a MPS per his settings adjusted for my altitude (sea level). The problem is that the factory settings are way too lean. I have confirmed this on another 914 as well. My theory is that cars were already set on "lean kill" from the factory to meet 70's emmisions with the technology they had. Add to that 10% ethanol and a free flowing exhaust (both my car and the other car have Bursch exhausts) and you have a very lean running car (solid white plugs and inside the exhaust header) that bucks on the factory settings. So an LCR just gives you a place to start IMO/experience. I have not yet added a wide band sensor, but that is the real solution. If that is not in your immediate future, I would have one set with an LCR and then turn the center screw out (richer) until it runs better. To do this easily you really need to drill the full throttle stop so that you do not lose that adjustment evertime you want to adjust the mixture. I believe both my and the other car are about 2 turns out on the center screw only. Start with 1/2 turn at a time until you are getting closer, then go 1/4 turn until there is almost no bucking at anything other than very light throttle, then go 1/8 turn or less until you are happy. You should find that the idle mixture adjusting knob on the box is close to the middle of the adjustment range. If you think your car is rich, I would not recommend leaning it out without a wide band sensor in place! I have put about 9000 miles on my car since adjusting this way and it always starts and gets decent mileage. |
| ape914 |
Jul 7 2012, 03:25 PM
red locktite ![]() ![]() Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
Very interesting. I'll order one, soon, and I'll update my page with the info on the kit. I get hits from round the world, from D-Jet owners far outside of the 914 community, so I may be able to drum up considerable interest (e.g. Volvo, M-B, Citroen, etc.). As for calibration, hate to tell you, but using either an LCR meter or a bench tester (like an EFI Associates tester) is the only way I know how to reliably set up an MPS. Too many variables to using a mechanical method (with a vernier depth gauge). My plan is to install a wide band sensor... so is there anyway to get it close first Chris and then adjust on the road or perhaps on a dyno? Right now I have a rebuilt unit...but I know it is running lean on part to full load. Goal is to change out to the kit and see what happens and then tune to the AFR gauge with the kit. Does this make sense given what Brad has said? Brads writing on the subject has been a great help to me in getting my car running well (thanks Brad!)! I have access to a LCR and setup a MPS per his settings adjusted for my altitude (sea level). The problem is that the factory settings are way too lean. I have confirmed this on another 914 as well. My theory is that cars were already set on "lean kill" from the factory to meet 70's emmisions with the technology they had. Add to that 10% ethanol and a free flowing exhaust (both my car and the other car have Bursch exhausts) and you have a very lean running car (solid white plugs and inside the exhaust header) that bucks on the factory settings. So an LCR just gives you a place to start IMO/experience. I have not yet added a wide band sensor, but that is the real solution. If that is not in your immediate future, I would have one set with an LCR and then turn the center screw out (richer) until it runs better. To do this easily you really need to drill the full throttle stop so that you do not lose that adjustment evertime you want to adjust the mixture. I believe both my and the other car are about 2 turns out on the center screw only. Start with 1/2 turn at a time until you are getting closer, then go 1/4 turn until there is almost no bucking at anything other than very light throttle, then go 1/8 turn or less until you are happy. You should find that the idle mixture adjusting knob on the box is close to the middle of the adjustment range. If you think your car is rich, I would not recommend leaning it out without a wide band sensor in place! I have put about 9000 miles on my car since adjusting this way and it always starts and gets decent mileage. thanks, great tuning info, What's an LCR? |
Racer Chris D-Jet MPS Diaphragm Replacement/Tuning Kits - In Stock May 30 2012, 10:20 AM
saigon71 Count me in for at least one kit.
Thanks for sett... May 30 2012, 11:13 AM
dknechtly Great idea. Hard to be patient for 4 to 5 months.... May 30 2012, 11:30 AM
vsg914 would these be for any mps, or particular ones? I... May 30 2012, 11:32 AM
Racer Chris
would these be for any mps, or particular ones? I... May 30 2012, 01:47 PM
falconfp2001 Would have been in on this if it were not for Mega... May 30 2012, 11:50 AM
rwilner
Would have been in on this if it were not for Meg... May 30 2012, 11:59 AM
falconfp2001
Would have been in on this if it were not for Me... May 30 2012, 12:46 PM
bdstone914
[quote name='rwilner' post='1684730' date='May 30... May 30 2012, 03:33 PM
Philip W. :Qarl: :worship:
chris, this is great! no... May 30 2012, 11:52 AM
phatnine11 Looks promising! Please keep us posted on the ... May 30 2012, 01:35 PM
brant I think the difference in 1.7s/2.0s are due to tun... May 30 2012, 01:56 PM
rhodyguy i would take at least 1.
k May 30 2012, 02:31 PM
rick 918-S Absolutely. Number one part that is killing our F.... May 30 2012, 02:36 PM
reharvey I'm in May 30 2012, 02:42 PM
bdstone914 Chris,
I know a board member here (MDShantz) that... May 30 2012, 03:37 PM
Ian Stott Chris, I am not as technical as you guys so I am n... May 30 2012, 03:41 PM
76-914 It's a rebuild kit for your MPS. Get one. If y... May 30 2012, 04:31 PM
StratPlayer IN May 30 2012, 04:36 PM
Jeff Bowlsby I'd be in for one at first to see how it all w... May 30 2012, 07:18 PM
rwilner I haven't seen Scott post in awhile but he was... May 30 2012, 08:06 PM
scott_in_nh
I haven't seen Scott post in awhile but he wa... Jun 1 2012, 05:43 PM
914_teener
I haven't seen Scott post in awhile but he w... Jun 1 2012, 07:19 PM
FourBlades I am in for one at least.
Folks may want to jump ... May 30 2012, 08:38 PM
jim_hoyland Nice addition for D Jet owners, way to go Chris ... May 30 2012, 09:25 PM
KELTY360 :angry: This sure hurts the value of the NOS MPS t... May 30 2012, 09:53 PM
watsonrx13 Count me in for one set.
--- Rob May 31 2012, 06:32 AM
914Bryan I will be in for two! Please advise how and wh... May 31 2012, 07:07 AM
zymurgist I'm in for 1. May 31 2012, 07:24 AM
cary I'm in for 2.
Keep us posted when you need the... May 31 2012, 08:20 AM
tradisrad Yep, I am interested. May 31 2012, 08:45 AM
sean_v8_914 YES! im in May 31 2012, 09:57 AM
kerensky My MPS hasn't been exercised in well over 20 y... May 31 2012, 11:17 AM
sofi2t81 Hello there,
ther is also the possibility to get ... May 31 2012, 05:04 PM
spankmeister7 I'm for at least one. Perhaps two. May 31 2012, 11:07 PM
Highland What equipment/tools would be required to assembly... May 31 2012, 11:13 PM
brant
What equipment/tools would be required to assembl... Jun 1 2012, 07:26 AM
mtburman +1, thanks, Jun 1 2012, 06:48 AM
gendent I will take two. One for the one in the car and on... Jun 1 2012, 10:07 AM
Racer Chris I think I'm going to offer the repair kit with... Jun 1 2012, 10:36 AM
02loftsmoor Help me here and no disrespect. what would be the... Jun 1 2012, 10:58 AM
Racer Chris
Help me here and no disrespect. what would be th... Jun 1 2012, 11:42 AM
pilothyer Chris.....Excellent idea...Count on me for 2 ........ Jun 1 2012, 11:31 AM
SLITS I believe that PP would get their units from Fuel ... Jun 1 2012, 04:18 PM
Bleyseng
I believe that PP would get their units from Fuel... Jun 5 2012, 04:32 AM
wingnut86 I'll just sell stuff till I hit $130.
Pu... Jun 1 2012, 07:19 PM
ConeDodger I have a couple used ones as well... No need to re... Jun 2 2012, 12:44 AM
Mikey914 I admire your willingness to take this on. I actua... Jun 2 2012, 02:37 AM
worn
I admire your willingness to take this on. I actu... Jun 5 2012, 10:31 AM
TJB/914 I agree with the lean issue.
Put me down for (1) ... Jun 2 2012, 04:52 AM
ThinAir I'm envious of you guys who have the ability t... Jun 4 2012, 11:59 PM
billh1963 Put me down for two! Jun 5 2012, 05:55 AM
plas76targa Chris, count me in for 1. PM details when $... Jun 5 2012, 06:16 AM
cary Just a heads up for those looking to purchase the ... Jun 5 2012, 09:05 AM
Racer Chris This morning I figured out how I'll make the h... Jun 5 2012, 11:52 AM
JRust I'd be in for one or 2 also! Thanks Jun 5 2012, 12:16 PM
KELTY360
:c... Jun 5 2012, 04:09 PM
walterolin I have room on my shelf for one.
Thanks
Olin Jun 5 2012, 12:35 PM
cary Here's the quote I finally got back from Bosch... Jun 13 2012, 07:36 AM
RobW I'm in just to support the cause. :cheer: Jun 13 2012, 08:28 AM
02loftsmoor I'll take one; Wes Jun 13 2012, 09:05 AM
Highland Has anyone used the Sinometer MS8222H Digital Mult... Jun 13 2012, 04:37 PM
tradisrad
Has anyone used the Sinometer MS8222H Digital Mul... Jun 23 2012, 10:07 AM
germag Count me in too... Jun 13 2012, 10:11 PM
sean_v8_914 i need good mps' Jun 13 2012, 11:06 PM
wingnut86 Sean,
I don't know you, but based on your thr... Jun 14 2012, 05:58 AM
Racer Chris I'm ready to start taking orders.
Introductory... Jun 21 2012, 09:24 AM
FourBlades Paypal sent!
Thanks for making these.
I am s... Jun 21 2012, 12:59 PM
brant Chris,
I have to gather some funds
I will buy so... Jun 21 2012, 01:00 PM
wingnut86 HaHAH!!
:Qarl: :Qarl: :Qarl: Jun 21 2012, 01:59 PM
saigon71 Just ordered one. Thanks Chris! Jun 21 2012, 02:55 PM
Racer Chris Since there will be a long delay until the kits ar... Jun 22 2012, 12:34 PM
plas76targa also just ordered one with tune up kit, from your ... Jun 22 2012, 12:58 PM
nathansnathan I just ordered a kit with the tools. I've got ... Jun 22 2012, 03:26 PM
396 Done via PayPal
Thanks Jun 22 2012, 11:19 PM
Racer Chris :bump:
Thanks to the 13 people who placed their or... Jun 25 2012, 08:36 AM
Racer Chris
My plan is to install a wide band sensor... so is... Jun 27 2012, 08:02 PM
pbanders
[quote name='914_teener' post='1700756' date='Jun... Jun 30 2012, 03:32 PM
Racer Chris
If you don't have an LCR to do the initia... Jul 2 2012, 05:27 PM
walterolin
[quote name='914_teener' post='1700756' date='Ju... Jul 7 2012, 04:40 PM
sean_v8_914 i just bought 3 cars so Im low on dough. good thin... Jun 26 2012, 08:09 AM
396 Free bump for more action :) Jun 26 2012, 09:59 PM
timofly Chris,
Please add me to the list. I have so much ... Jun 28 2012, 07:28 PM
Racer Chris
Chris,
Please add me to the list. I have so much... Jun 28 2012, 08:00 PM
ape914 hey, you might want to offer these new parts over ... Jul 4 2012, 11:37 AM
Racer Chris Thats a good idea. Jul 4 2012, 07:55 PM
Racer Chris :bump: Jul 7 2012, 06:26 AM
Racer Chris I know getting 100 paid orders in 5 weeks is rathe... Jul 9 2012, 10:05 AM
Jeff Bowlsby
I know getting 100 paid orders in 5 weeks is rath... Jul 9 2012, 10:31 AM
Jeff Bowlsby :) Jul 9 2012, 10:32 AM
wingnut86 Thanks Jeff!
Now all we have to do is join en... Jul 9 2012, 01:01 PM
Jeff Bowlsby I have posted this info/link to the benzworld.org ... Jul 9 2012, 02:15 PM
Racer Chris I contacted my cousin who is a former Saab club p... Jul 9 2012, 02:50 PM
76-914 I may be one of many Chris. I will want 2 diaphrag... Jul 9 2012, 03:44 PM
Racer Chris
I may be one of many Chris. I will want 2 diaphra... Jul 9 2012, 07:18 PM
Jeff Bowlsby Posted now to the Volvo 1800 whre I received this ... Jul 9 2012, 04:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:18 AM |
