> Charcoal Filter - Do You Really Need it?
kbrunk1
post Jul 14 2012, 07:17 PM
Brunk
I am bringing back a 73 2.0L Djetronic 914 with the Charcoal canister beside the gas tank. I am also relocating the fuel pump below the gas tank.
Do you really need the charcoal filter?
Also the gas vapor gas / expansion tank also seems worthless.
Anyone an expert on this subject? Can you just plug some of these vapor lines and not effect the engine running? I think emissions are exempt on this year car.
I would like to make this as simple as possible.
Thanks
dlestep
post Jul 14 2012, 08:07 PM
I am smilin'...
The expansion tank should remain, with new hoses.
You can relocate the charcoal canister to the driverside inner fender (where the
914-6 oil tank lives). the two black plastic lines run from the tank to the engine
bay. One line connects to the fan housing, pressurizing the flow of the ELS.
The other one returns to the engine bay and is connected to induction.
You can cut the stock lines allowing the relocation.
Do not forget to use the filler neck hose to route overflow below the floor and
underneath the car.
There are schematics of the evaporative loss system for your car, here and
elsewhere on internet that you can use as an example.
Without the ELS lines, you WILL smell gas, especially in the heat of the day.
There are other ways, such as dry sumping carbs, and routing scavage lines
from the expansion tank via check valves to the exhaust bungs.
(You must NOT draw directly from the tank!).
kbrunk1   Charcoal Filter - Do You Really Need it?   Jul 14 2012, 07:17 PM
FourBlades   All these parts keep the smell of gas out of your ...   Jul 14 2012, 07:35 PM
zonedoubt   And refill the canister with fresh charcoal. The o...   Jul 15 2012, 12:28 PM
dlestep   The expansion tank should remain, with new hoses. ...   Jul 14 2012, 08:07 PM
Millerwelds   I removed them to clean things up as well. The gas...   Jul 14 2012, 09:19 PM
Rand   Can you just plug some of these vapor lines and n...   Jul 14 2012, 09:21 PM
iamchappy   I removed it and routed the line back to the air f...   Jul 14 2012, 09:41 PM
Rand   Ding! A nice example of routing lines nicely. ...   Jul 14 2012, 11:27 PM
McMark   I don't get removing it, especially from a 73 ...   Jul 15 2012, 10:20 AM
9146986   Little to no downside for taking off. Pretty much...   Jul 15 2012, 01:05 PM
sixerdon   My experience says they are not needed. I've s...   Jul 15 2012, 03:33 PM
sixerdon   More filter discussion here....... http://www.914...   Jul 15 2012, 03:38 PM
wndsnd   If you go fro fi to carbs, how does it tie in. I...   Jul 15 2012, 06:32 PM
Pat Garvey   Guess I'm wierd. Replaced mine at 50K miles, ...   Jul 15 2012, 06:57 PM
rdauenhauer   On early cars so equipped the canisters were prett...   Jul 15 2012, 11:33 PM
Vysoc   Hello World, I just got in a big fight with my wi...   Jul 16 2012, 08:31 AM
Vysoc   Answered my own question, I just bought a brand n...   Jul 16 2012, 08:59 AM
zonedoubt   ...now where are the pellets available? I poste...   Jul 16 2012, 01:31 PM
Vysoc   Thanks Zonedoubt, Thanks for the info, was unsure...   Jul 16 2012, 05:17 PM
ruby914   I took the trouble of getting the charcoal caniste...   Jul 16 2012, 07:55 PM
broomhandle   i just switched to carb, i upluged them in the e-B...   Jul 17 2012, 11:05 AM
Vysoc   After struggling for many years with garage vapor ...   Jul 23 2012, 09:04 PM
ruby914   After struggling for many years with garage vapor...   Jul 23 2012, 10:02 PM
horizontally-opposed   Just unearthed my old expansion tank while cleanin...   Feb 6 2022, 05:37 PM
SirAndy   I am bringing back a 73 2.0L Djetronic 914 with th...   Feb 6 2022, 06:08 PM
windforfun   I am bringing back a 73 2.0L Djetronic 914 with t...   Feb 6 2022, 09:17 PM
Van B   If I don’t want to go into a dope shop, where ca...   Feb 6 2022, 10:59 PM
Craigers17   If I don’t want to go into a dope shop, where c...   Feb 7 2022, 06:30 AM
Van B   If I don’t want to go into a dope shop, where ...   Feb 7 2022, 08:15 AM
Steve   I used this one. https://www.petsmart.com/fish/fil...   Feb 7 2022, 08:50 AM
Van B   Would those small flakes get sucked through the ca...   Feb 7 2022, 09:36 AM
StarBear   Would those small flakes get sucked through the c...   Feb 7 2022, 10:44 AM
Steve   Would those small flakes get sucked through the c...   Feb 7 2022, 01:58 PM
rhodyguy   Van, you NEED to buy the activated charcoal in pel...   Feb 7 2022, 09:41 AM
Craigers17   Van, I used the pelletized form as well. I just f...   Feb 7 2022, 11:59 AM
Amphicar770   There is no apparent benefit to removing it, perfo...   Feb 7 2022, 01:30 PM
Van B   Thanks guys! @Craigers17 you’re a scholar ...   Feb 7 2022, 02:03 PM
wonkipop   Thanks guys! [b]@[url=http://www.914world.co...   Feb 7 2022, 03:54 PM
Van B   Well, I pried open my canister today. And as suspe...   Feb 8 2022, 01:47 PM
wonkipop   thanks for the look inside. so what you are sayin...   Feb 8 2022, 03:39 PM
JeffBowlsby   Your pellets are too small.   Feb 8 2022, 03:51 PM
lesorubcheek   Your pellets are too small. That's what she ...   Feb 8 2022, 05:13 PM
Van B   No. Those pellets, as you see them, are too small....   Feb 8 2022, 04:00 PM
wonkipop   No. Those pellets, as you see them, are too small...   Feb 8 2022, 04:07 PM
wonkipop   good thing he opened it up then. someone must hav...   Feb 8 2022, 04:00 PM
Van B   good thing he opened it up then. someone must ha...   Feb 8 2022, 04:14 PM
wonkipop   [quote name='wonkipop' post='2980517' date='Feb 8...   Feb 8 2022, 04:37 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:51 PM
