> Can I make a Master Key from Valet Key?
skaufmann
post Jul 18 2012, 12:36 PM
Blissfully Ignorant
I only have the original Valet key that turns the ignition. I have a 2nd key (Master) that opens the passenger door (and nothing else) and a 3rd key (Valet) that open the driver door (and nothing else).
From what I can gather, the only difference between the master key and the valet key is the channeling down the side of the key, not the notch/tooth profile. If I'm correct, can I make a copy of the original Valet key to a new Master key?
My thought is it's easier to rekey the door locks and I suspect the new Master will then work the trunk and glove box since those were not likely replaced like the door locks were.
markb
post Jul 18 2012, 01:10 PM
914less :(
GPR sells originals & repros of the keys. Take the best key you have, and rekey everything to that key. Most places that make keys can make the copies. My local Ace hardware does them for me. Follow the rekey thread (it's in my signature) and do the rest of them. If you take the glove box lock out & use those wafers for the spares, then key the ignition, doors, rear trunk, front trunk then the glove box, in that order, you should come pretty close. If you need some extra wafers, at least the exterior stuff is done, so you can drive the car while you source the extras.
skaufmann   Can I make a Master Key from Valet Key?   Jul 18 2012, 12:36 PM
r_towle   You should be able to use the valet key to make a ...   Jul 18 2012, 12:46 PM
skaufmann   You should be able to use the valet key to make a...   Jul 18 2012, 12:51 PM
r_towle   If I recall correctly, the glove box and front tru...   Jul 18 2012, 01:02 PM
markb   GPR sells originals & repros of the keys. Take...   Jul 18 2012, 01:10 PM
skaufmann   Awesome help guys! Is there a source for wafe...   Jul 18 2012, 02:39 PM
markb   Awesome help guys! Is there a source for waf...   Jul 18 2012, 02:48 PM
barefoot   Awesome help guys! Is there a source for wa...   Jun 27 2013, 08:02 AM
doug_b_928   My car only came with a valet key. Reading on the...   Feb 18 2017, 08:19 PM
Racer Chris   My car only came with a valet key. Reading on th...   Feb 20 2017, 02:05 PM
doug_b_928   Bump in the hopes that someone with a better under...   Feb 19 2017, 08:09 PM
914 RZ-1   When I got my car I had 3 keys to various combinat...   Feb 19 2017, 09:58 PM
doug_b_928   Good to know that might be an option.   Feb 20 2017, 06:24 AM
slivel   I recently had an extra key made for my 1975 914 a...   Feb 20 2017, 11:15 AM
doug_b_928   Hmmm...so maybe I can try it out with a blank from...   Feb 20 2017, 11:53 AM
The Cabinetmaker   The cut is the same on both master and valet. Yes,...   Feb 20 2017, 01:17 PM
doug_b_928   The nuance that was not obvious to me is whether t...   Feb 20 2017, 01:26 PM
doug_b_928   Very nice explanation. Thank you!   Feb 20 2017, 02:46 PM
- Lo-Fi Version Time is now: 19th November 2025 - 06:39 PM
