> steering wheel/shaft play
mrbubblehead
post Jul 19 2012, 05:33 PM
Twodollardoug
i have searched and searched, but cant find the right fix. i have a 74 914/4. my steering wheel shaft has side to side and up and down play. not a ton of play. but enuff to be annoying. and i need to fix it. i have found a number of fixes but they seem to be for early 911s. one fix is to replace the upper and lower bearings. another is to insert a sleeve between the bearing and shaft (thats what it looks like to me anyways). and the last looks a split ring over the shaft and then a plastic race looking thing followed by a spring to hold the race in place when the steering wheel is reinstalled.
is there a right up specific to our cars that i have missed? or has anyone made this repair. i sure would like to tighten up the shaft.
thanks for your help.
doug
A&PGirl
post Jul 19 2012, 05:43 PM
Hi Doug,
Yes, it is annoying problem. (IMG:style_emoticons/default/dry.gif)
Usually, you'll need to replace the bearing in the steering column switch and what is called the "guide bush" that rides on the shaft. The shaft the guide bush rides sits inside of the bearing.
75% of the time you're good to go after this. (IMG:style_emoticons/default/cheer.gif)
If you're a lucky one you may need to replace loose u joints and the rest of the bearings.
mrbubblehead   steering wheel/shaft play   Jul 19 2012, 05:33 PM
SLITS   It's a 928 part number Steering Bushing Comm...   Jul 19 2012, 05:39 PM
SirAndy   It's a 928 part number But the plastic bushing...   Jul 20 2012, 11:45 AM
Jeffs9146   Steering Shaft Bearing Replacement Thread   Jul 19 2012, 05:41 PM
A&PGirl   Hi Doug, Yes, it is annoying problem. <_< ...   Jul 19 2012, 05:43 PM
mrbubblehead   so is it the bearing AND the bushing that wears ou...   Jul 19 2012, 05:50 PM
A&PGirl   It will usually be obvious. However, common sens...   Jul 19 2012, 06:12 PM
reharvey   The bearing will sometimes be loose where it sits ...   Jul 19 2012, 06:26 PM
mrbubblehead   please forgive me.... so is the replacement shaft ...   Jul 19 2012, 06:33 PM
bigkensteele   please forgive me.... so is the replacement shaft...   Jul 19 2012, 06:52 PM
mrbubblehead   please forgive me.... so is the replacement shaf...   Jul 19 2012, 07:01 PM
A&PGirl   Yes, you need both.   Jul 19 2012, 06:35 PM
mrbubblehead   Yes, you need both. great, thank you.   Jul 19 2012, 06:40 PM
mrbubblehead   i spoke too soon. i see now....   Jul 19 2012, 07:08 PM
ThePaintedMan   Bubbles, I just finished tearing mine apart to...   Jul 19 2012, 08:42 PM
Racer Chris   I'm sure McMaster has to have a suitable rep...   Jul 19 2012, 08:56 PM
mrbubblehead   i just took mine apart. the bearing was tight on t...   Jul 19 2012, 10:51 PM
bigkensteele   i just took mine apart. the bearing was tight on ...   Jul 19 2012, 11:04 PM
mrbubblehead   i just took mine apart. the bearing was tight on...   Jul 19 2012, 11:12 PM
reharvey   i just took mine apart. the bearing was tight on ...   Jul 20 2012, 07:01 AM
bigkensteele   If I were you, and I pretty much am since I have t...   Jul 19 2012, 11:19 PM
mrbubblehead   thanks, bro. im just gonna get the bearing and do ...   Jul 19 2012, 11:24 PM
Racer Chris   Green Locktite (for bearing retention) would be be...   Jul 20 2012, 06:32 AM
ThePaintedMan   I think I have a similar problem then. Its not the...   Jul 20 2012, 08:05 AM
mrbubblehead   . Thats okay, my shaft needs a little play from t...   Jul 20 2012, 08:42 AM
ThePaintedMan   i was wondering how long it would be until the fi...   Jul 20 2012, 09:07 AM
broomhandle   I have this same issue, i was thinking its a beari...   Jul 20 2012, 10:22 AM
Brian_Boss   No. Early column uses a different bearing that doe...   Jul 20 2012, 10:35 AM
mrbubblehead   No. Early column uses a different bearing that do...   Jul 20 2012, 10:54 AM
sfrenck   Forget the bushing and use this method: Replacing...   Jul 20 2012, 11:39 AM
broomhandle   Forget the bushing and use this method: Replacin...   Jul 20 2012, 11:43 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:43 PM
