| mrbubblehead |
Jul 19 2012, 05:33 PM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i have searched and searched, but cant find the right fix. i have a 74 914/4. my steering wheel shaft has side to side and up and down play. not a ton of play. but enuff to be annoying. and i need to fix it. i have found a number of fixes but they seem to be for early 911s. one fix is to replace the upper and lower bearings. another is to insert a sleeve between the bearing and shaft (thats what it looks like to me anyways). and the last looks a split ring over the shaft and then a plastic race looking thing followed by a spring to hold the race in place when the steering wheel is reinstalled.
is there a right up specific to our cars that i have missed? or has anyone made this repair. i sure would like to tighten up the shaft. thanks for your help. doug |
| A&PGirl |
Jul 19 2012, 06:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
Yes, you need both.
| mrbubblehead |
Jul 19 2012, 06:40 PM
mrbubblehead steering wheel/shaft play Jul 19 2012, 05:33 PM
SLITS It's a 928 part number
Steering Bushing
Comm... Jul 19 2012, 05:39 PM
SirAndy It's a 928 part number
But the plastic bushing... Jul 20 2012, 11:45 AM
Jeffs9146 Steering Shaft Bearing Replacement Thread Jul 19 2012, 05:41 PM
A&PGirl Hi Doug,
Yes, it is annoying problem. <_< ... Jul 19 2012, 05:43 PM
mrbubblehead so is it the bearing AND the bushing that wears ou... Jul 19 2012, 05:50 PM
A&PGirl It will usually be obvious.
However, common sens... Jul 19 2012, 06:12 PM
reharvey The bearing will sometimes be loose where it sits ... Jul 19 2012, 06:26 PM
mrbubblehead please forgive me.... so is the replacement shaft ... Jul 19 2012, 06:33 PM
bigkensteele
please forgive me.... so is the replacement shaft... Jul 19 2012, 06:52 PM
mrbubblehead
please forgive me.... so is the replacement shaf... Jul 19 2012, 07:01 PM
mrbubblehead i spoke too soon. i see now.... Jul 19 2012, 07:08 PM
ThePaintedMan Bubbles,
I just finished tearing mine apart to... Jul 19 2012, 08:42 PM
Racer Chris
I'm sure McMaster has to have a suitable rep... Jul 19 2012, 08:56 PM
mrbubblehead i just took mine apart. the bearing was tight on t... Jul 19 2012, 10:51 PM
bigkensteele
i just took mine apart. the bearing was tight on ... Jul 19 2012, 11:04 PM
mrbubblehead
i just took mine apart. the bearing was tight on... Jul 19 2012, 11:12 PM
reharvey
i just took mine apart. the bearing was tight on ... Jul 20 2012, 07:01 AM
bigkensteele If I were you, and I pretty much am since I have t... Jul 19 2012, 11:19 PM
mrbubblehead thanks, bro. im just gonna get the bearing and do ... Jul 19 2012, 11:24 PM
Racer Chris Green Locktite (for bearing retention) would be be... Jul 20 2012, 06:32 AM
ThePaintedMan I think I have a similar problem then. Its not the... Jul 20 2012, 08:05 AM
mrbubblehead
. Thats okay, my shaft needs a little play from t... Jul 20 2012, 08:42 AM
ThePaintedMan
i was wondering how long it would be until the fi... Jul 20 2012, 09:07 AM
broomhandle I have this same issue, i was thinking its a beari... Jul 20 2012, 10:22 AM
Brian_Boss No. Early column uses a different bearing that doe... Jul 20 2012, 10:35 AM
mrbubblehead
No. Early column uses a different bearing that do... Jul 20 2012, 10:54 AM
sfrenck Forget the bushing and use this method:
Replacing... Jul 20 2012, 11:39 AM
broomhandle
Replacin... Jul 20 2012, 11:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:39 PM |
