| mrbubblehead |
Jul 19 2012, 05:33 PM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i have searched and searched, but cant find the right fix. i have a 74 914/4. my steering wheel shaft has side to side and up and down play. not a ton of play. but enuff to be annoying. and i need to fix it. i have found a number of fixes but they seem to be for early 911s. one fix is to replace the upper and lower bearings. another is to insert a sleeve between the bearing and shaft (thats what it looks like to me anyways). and the last looks a split ring over the shaft and then a plastic race looking thing followed by a spring to hold the race in place when the steering wheel is reinstalled.
is there a right up specific to our cars that i have missed? or has anyone made this repair. i sure would like to tighten up the shaft. thanks for your help. doug |
| bigkensteele |
Jul 19 2012, 11:19 PM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
If I were you, and I pretty much am since I have the same problem, I would spend the $41 and replace the bearing. After it is done, you will know where you stand. I don't think that there will be play between the shaft and the bearing. If there is play between the outer race and the column, you can shim it in any way you see fit. Good luck, brother.
mrbubblehead steering wheel/shaft play Jul 19 2012, 05:33 PM
SLITS It's a 928 part number
Steering Bushing
Comm... Jul 19 2012, 05:39 PM
SirAndy It's a 928 part number
But the plastic bushing... Jul 20 2012, 11:45 AM
Jeffs9146 Steering Shaft Bearing Replacement Thread Jul 19 2012, 05:41 PM
A&PGirl Hi Doug,
Yes, it is annoying problem. <_< ... Jul 19 2012, 05:43 PM
mrbubblehead so is it the bearing AND the bushing that wears ou... Jul 19 2012, 05:50 PM
A&PGirl It will usually be obvious.
However, common sens... Jul 19 2012, 06:12 PM
reharvey The bearing will sometimes be loose where it sits ... Jul 19 2012, 06:26 PM
mrbubblehead please forgive me.... so is the replacement shaft ... Jul 19 2012, 06:33 PM
bigkensteele
please forgive me.... so is the replacement shaft... Jul 19 2012, 06:52 PM
mrbubblehead
please forgive me.... so is the replacement shaf... Jul 19 2012, 07:01 PM
A&PGirl Yes, you need both. Jul 19 2012, 06:35 PM
mrbubblehead
Yes, you need both.
great, thank you. Jul 19 2012, 06:40 PM
mrbubblehead i spoke too soon. i see now.... Jul 19 2012, 07:08 PM
ThePaintedMan Bubbles,
I just finished tearing mine apart to... Jul 19 2012, 08:42 PM
Racer Chris
I'm sure McMaster has to have a suitable rep... Jul 19 2012, 08:56 PM
mrbubblehead i just took mine apart. the bearing was tight on t... Jul 19 2012, 10:51 PM
bigkensteele
i just took mine apart. the bearing was tight on ... Jul 19 2012, 11:04 PM
mrbubblehead
i just took mine apart. the bearing was tight on... Jul 19 2012, 11:12 PM
reharvey
i just took mine apart. the bearing was tight on ... Jul 20 2012, 07:01 AM
mrbubblehead thanks, bro. im just gonna get the bearing and do ... Jul 19 2012, 11:24 PM
Racer Chris Green Locktite (for bearing retention) would be be... Jul 20 2012, 06:32 AM
ThePaintedMan I think I have a similar problem then. Its not the... Jul 20 2012, 08:05 AM
mrbubblehead
. Thats okay, my shaft needs a little play from t... Jul 20 2012, 08:42 AM
ThePaintedMan
i was wondering how long it would be until the fi... Jul 20 2012, 09:07 AM
broomhandle I have this same issue, i was thinking its a beari... Jul 20 2012, 10:22 AM
Brian_Boss No. Early column uses a different bearing that doe... Jul 20 2012, 10:35 AM
mrbubblehead
No. Early column uses a different bearing that do... Jul 20 2012, 10:54 AM
sfrenck Forget the bushing and use this method:
Replacing... Jul 20 2012, 11:39 AM
broomhandle
Replacin... Jul 20 2012, 11:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:55 AM |
