> steering wheel/shaft play
mrbubblehead
post Jul 19 2012, 05:33 PM
Twodollardoug
i have searched and searched, but cant find the right fix. i have a 74 914/4. my steering wheel shaft has side to side and up and down play. not a ton of play. but enuff to be annoying. and i need to fix it. i have found a number of fixes but they seem to be for early 911s. one fix is to replace the upper and lower bearings. another is to insert a sleeve between the bearing and shaft (thats what it looks like to me anyways). and the last looks a split ring over the shaft and then a plastic race looking thing followed by a spring to hold the race in place when the steering wheel is reinstalled.
is there a right up specific to our cars that i have missed? or has anyone made this repair. i sure would like to tighten up the shaft.
thanks for your help.
doug
SLITS
post Jul 19 2012, 05:39 PM
"This Utah shit is HARSH!"
It's a 928 part number
Steering Bushing
Common replacement
post Jul 20 2012, 11:45 AM
Resident German
QUOTE(SLITS @ Jul 19 2012, 04:39 PM) *
But the plastic bushings suck, they don't last long.
There's also a (corrugated) metal sleeve that goes between the shaft and the bearing, which works much better than the plastic thing.
mrbubblehead   steering wheel/shaft play   Jul 19 2012, 05:33 PM
SLITS   It's a 928 part number Steering Bushing Comm...   Jul 19 2012, 05:39 PM
SirAndy   It's a 928 part number But the plastic bushing...   Jul 20 2012, 11:45 AM
Jeffs9146   Steering Shaft Bearing Replacement Thread   Jul 19 2012, 05:41 PM
A&PGirl   Hi Doug, Yes, it is annoying problem. <_< ...   Jul 19 2012, 05:43 PM
mrbubblehead   so is it the bearing AND the bushing that wears ou...   Jul 19 2012, 05:50 PM
A&PGirl   It will usually be obvious. However, common sens...   Jul 19 2012, 06:12 PM
reharvey   The bearing will sometimes be loose where it sits ...   Jul 19 2012, 06:26 PM
mrbubblehead   please forgive me.... so is the replacement shaft ...   Jul 19 2012, 06:33 PM
bigkensteele   please forgive me.... so is the replacement shaft...   Jul 19 2012, 06:52 PM
mrbubblehead   please forgive me.... so is the replacement shaf...   Jul 19 2012, 07:01 PM
A&PGirl   Yes, you need both.   Jul 19 2012, 06:35 PM
mrbubblehead   Yes, you need both. great, thank you.   Jul 19 2012, 06:40 PM
mrbubblehead   i spoke too soon. i see now....   Jul 19 2012, 07:08 PM
ThePaintedMan   Bubbles, I just finished tearing mine apart to...   Jul 19 2012, 08:42 PM
Racer Chris   I'm sure McMaster has to have a suitable rep...   Jul 19 2012, 08:56 PM
mrbubblehead   i just took mine apart. the bearing was tight on t...   Jul 19 2012, 10:51 PM
bigkensteele   i just took mine apart. the bearing was tight on ...   Jul 19 2012, 11:04 PM
mrbubblehead   i just took mine apart. the bearing was tight on...   Jul 19 2012, 11:12 PM
reharvey   i just took mine apart. the bearing was tight on ...   Jul 20 2012, 07:01 AM
bigkensteele   If I were you, and I pretty much am since I have t...   Jul 19 2012, 11:19 PM
mrbubblehead   thanks, bro. im just gonna get the bearing and do ...   Jul 19 2012, 11:24 PM
Racer Chris   Green Locktite (for bearing retention) would be be...   Jul 20 2012, 06:32 AM
ThePaintedMan   I think I have a similar problem then. Its not the...   Jul 20 2012, 08:05 AM
mrbubblehead   . Thats okay, my shaft needs a little play from t...   Jul 20 2012, 08:42 AM
ThePaintedMan   i was wondering how long it would be until the fi...   Jul 20 2012, 09:07 AM
broomhandle   I have this same issue, i was thinking its a beari...   Jul 20 2012, 10:22 AM
Brian_Boss   No. Early column uses a different bearing that doe...   Jul 20 2012, 10:35 AM
mrbubblehead   No. Early column uses a different bearing that do...   Jul 20 2012, 10:54 AM
sfrenck   Forget the bushing and use this method: Replacing...   Jul 20 2012, 11:39 AM
broomhandle   Forget the bushing and use this method: Replacin...   Jul 20 2012, 11:43 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:54 AM
