Setting up a 915 Trans in a 914, Vent question |
ChrisFoley |
Jul 24 2012, 07:08 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Whats the correct orientation of the top vent on a 915 trans when set up for use in a 914?
The bottom of the vent tube is cut on a 45 degree angle and the cut is aimed away from the ring gear at a particular angle. However, reversing the R&P changes the relative position of the angle cut to the ring gear. The vent tube must also be repositioned for it to work properly in a 914. If the angle cut orientation is wrong, gear oil will be flung into the vent tube, temporarily sealing the vent and pressurizing the gear case as it heats up, causing oil to go past the flange seals and make a mess on the outside. We had this happen in a 912E once when the customer's local mechanic had filled the trans thru the vent hole and screwed it back in all the way without regard for orientation. So the question is, which direction does the hole in the top of the vent aim in a 914? |
Steve |
Jul 24 2012, 09:24 AM
914 Guru Group: Members Posts: 5,614 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
You would think it would be the same as the 914 trans, angled towards the battery. Can you compare the breather with a 914 breather? I am also installing a 915 trans in my 914 and I am debating on whether to use the breather or the existing puke bottle in the trunk.
Lo-Fi Version | Time is now: 10th June 2024 - 04:09 AM |
