Remote starter solenoid, Good, bad or ugly? |
Jesco Reient |
Jul 26 2012, 10:26 AM
Member Group: Members Posts: 135 Joined: 18-July 12 From: Western Washington Member No.: 14,690 Region Association: Pacific Northwest |
Ok so I've spent another lovely day working on the 914, The harness from the relay has some bad wiring in it. So I'm taking it out to replace it. I get to the starter and there is a Ford starter solenoid remote mounted where it is fairly easy to reach from underneath the car. Now I know this is not factory, but is this a common modification that some people think is a good idea? or is this a band aid fix for something worse?
Bartlett 914 |
Jul 26 2012, 11:42 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
A solenoid pulls a lot of current. This can put a strain on the ignition switch. Adding another solenoid doesn't really solve this. You can use a small relay with contacts that can handle the stock solenoid. These are commonly available at your FLAPS. These will have low current coils (good for the ignition switch) and contacts that will work your solenoid. Should the relay fail, it is very easy to go back to stock. While true that there may be other problems, I use a relay as a preventative measure.
Lo-Fi Version | Time is now: 13th June 2024 - 01:23 AM |
