| NJ914Guy |
Jul 25 2012, 08:22 PM
Member ![]() ![]() Group: Members Posts: 150 Joined: 30-December 10 From: Deptford, NJ Member No.: 12,546 Region Association: MidAtlantic Region |
My car is a 1973 914 2.0 running dual Weber 40 carbs, an Aircooled.net SVDA vac advance distributor (vac port connected to dual carbs) and a Pertronix electronic ignition module.
Here in NJ, on a 80-90 degree day, the car runs great on the back roads ranging from 30-45 MPH. Using the dip stick temp gauge, she runs around 180-195 for oil temp. If I take her up ont the highway and run the car at 65-80 MPH for 10-20 minutes, the temp will run up to 220-240, based on the outside air temps, which seems too hot. I assume that since I am fine on the back roads, my flaps and fan are clear and working fine? I do have 100% of the factory tins in place, and from 180-240 degrees, the car runs strong at all temps. I am thinking that I have a problem and would like to rule out some things. Here's my list of things to try. Please feel free to comment or make additional suggestions. 1. Change oil. I am running 10W-30 now. Have some fresh Brad Penn 20W-50 on hand. Could an oil change help? 2. Drop the oil screen and check for any sludge or blockage which may be impacting oil flow. 3. Check timing on the SVDA dizzy. I am wondering if it's advancing a little too much on the highway? Per John's instruction, when we installed the dizzy we set timing to: 38-45 Total Advance (hose connected) @ 3500 RPM. 4. Pull spark plugs and check for lean conditions. 5. Check carbs and idle jets. Not sure what's in there, but I hear that I want idle jets of 50. |
| NJ914Guy |
Jul 26 2012, 11:01 AM
What's a good range for O2 on a carbed 914?
| ape914 |
Jul 26 2012, 11:26 AM
red locktite ![]() ![]() Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
What's a good range for O2 on a carbed 914? depends on your engine, but in cruise a bit on the rich side is ok on an aircooled car, else they will run hotter. you might try around 12.5:1 and see if that effects your temps. you got carbs, so go one jet size bigger and see what happens. a spark plug reading can help you. if your carbs were set for the old gas, they will run too lean with todays oxygenated fuel. old gas =gasoline new gas = gasolean |
| ChrisFoley |
Jul 26 2012, 12:06 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,035 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
but in cruise a bit on the rich side is ok on an aircooled car, else they will run hotter. That's actually a common misconception. The engine will run plenty cool and get better gas mileage during light throttle operation if the AFR is between 16-17:1. For full load operation you need the mixture no leaner than 13.2:1, with 12.5-12.8:1 being used more often to create larger a safety margin. Anything between 14-15:1 will make the heads run hotter. |
NJ914Guy Running Hot on the Highway Jul 25 2012, 08:22 PM
mrbubblehead
My car is a 1973 914 2.0 running dual Weber 40 ca... Jul 25 2012, 09:03 PM
Racer Chris I agree with Doug.
I've been using Brad Penn ... Jul 26 2012, 06:24 AM
NJ914Guy Guys, here's John's timing settings, copye... Jul 26 2012, 06:57 AM
Racer Chris
I'd set the timing at 28 btdc, vac advance d... Jul 26 2012, 07:31 AM
Racer Chris
Should I pick-up a special type of timing gun?
... Jul 26 2012, 07:36 AM
NJ914Guy Thank you, Chris! Jul 26 2012, 08:11 AM
ape914 check your mixture too. lean running by even a sma... Jul 26 2012, 10:04 AM
r_towle I would suggest you listen to Chris.
Chris has ta... Jul 26 2012, 12:25 PM
ape914
Chris has t... Jul 27 2012, 01:26 PM
r_towle
Chris has ... Jul 27 2012, 07:51 PM
Racer Chris And I talk with my dad a lot. :)
He's a PhD ... Jul 26 2012, 01:30 PM
ape914
He's a PhD... Jul 27 2012, 01:56 PM
Racer Chris
Your Dad and my Dad have a lot in common, may... Jul 27 2012, 03:23 PM
ape914
[quote name='ape914' post='1715722' date='Jul 27 ... Jul 27 2012, 04:56 PM
ape914
Your Dad and my Dad have a lot in common, ma... Jul 28 2012, 09:21 AM
MikeM Sorry about the hi-jack...
Chris, you run Brad Pen... Jul 26 2012, 02:07 PM
Racer Chris
Chris, you run Brad Pe... Jul 26 2012, 03:00 PM
MikeM Thanks Chris...I'm going to try Valvoline VR1 ... Jul 26 2012, 03:22 PM
The Cabinetmaker The valvoline no longer has zinc in it, IIRC Jul 26 2012, 03:30 PM
MikeM Damn...not even the Vr1? Jul 26 2012, 03:31 PM
SLITS Want oil .... The "new" Kendall Gt-1 oil... Jul 26 2012, 03:40 PM
MikeM Probably not available in my area... Jul 26 2012, 03:43 PM
Racer Chris There are some motorcycle oils that still contain ... Jul 26 2012, 04:02 PM
bembry 1. What is the safe range for oil temps? Is 240 ... Jul 26 2012, 05:32 PM
mrholland2 Zinc? Do we really need zinc on a fully rebuild m... Jul 26 2012, 06:03 PM
Racer Chris
Zinc? Do we really need zinc on a fully rebuild ... Jul 26 2012, 07:15 PM
mrholland2 I've asked for oil with zinc and I get looked ... Jul 26 2012, 08:05 PM
jcd914
I've asked for oil with zinc and I get looked... Jul 26 2012, 11:39 PM
Rand
Zinc? Do we really need zinc on a fully rebuild ... Jul 26 2012, 11:29 PM
wingnut86 I agree with Rich's take on Chris as well.
Pl... Jul 26 2012, 09:29 PM
ape914
P... Jul 27 2012, 02:03 PM
kerensky If I can't find oil with zinc, can I just scra... Jul 26 2012, 11:21 PM
Rand
If I can't find oil with zinc, can I just scr... Jul 26 2012, 11:30 PM
Rand FWIW, there are some oils left.
I've rambled a... Jul 26 2012, 11:28 PM
bembry :miles: :miles: :miles: Jul 27 2012, 07:12 PM
mrbubblehead i am running the amsoil hot rod 5/30wt- zinc fort... Jul 27 2012, 07:40 PM
Woody Ape who are you? What are your credentials? All yo... Jul 27 2012, 08:58 PM
ape914
Ape who are you? What are your credentials? All y... Jul 28 2012, 09:16 AM
The Cabinetmaker He's our thread locker. Whenever an informativ... Jul 27 2012, 09:12 PM
ape914
He's our thread locker. Whenever an informati... Jul 30 2012, 12:39 PM
mrholland2 Here's my question now: Of the total "oi... Jul 27 2012, 09:18 PM
wingnut86 Wow.
Talk about going "Ape-Shit"
Also... Jul 27 2012, 09:31 PM
mrholland2 *sighs* best thing to do with that type is ignore... Jul 27 2012, 09:33 PM
tradisrad How can we get both power and lean burn out of our... Jul 28 2012, 12:43 PM
Dave_Darling If my understanding is correct, peak EGTs would be... Jul 28 2012, 01:39 PM
tradisrad Dave, You are right about comparing the Honda to t... Jul 28 2012, 02:57 PM
mrbubblehead
Is it possible for the OP to set his carbs to r... Jul 28 2012, 05:36 PM
ape914
Is it possible for the OP to set his carbs to ... Jul 28 2012, 05:49 PM
tradisrad
yes, that is the best thing about weber idf's... Jul 28 2012, 06:50 PM
ape914
[quote name='mrbubblehead' post='1716193' date='J... Jul 30 2012, 12:17 PM
r_towle
Is it possible for the OP to set his carbs to ... Jul 30 2012, 12:51 PM
ape914
[quote name='mrbubblehead' post='1716193' date='J... Jul 30 2012, 01:39 PM
ape914 from what i know about lean burning and aero engin... Jul 28 2012, 03:26 PM
ape914 One other thing that can be added to the tunning t... Jul 30 2012, 12:10 PM
Racer Chris No different, I got the procedure from mrbubblehea... Jul 30 2012, 01:41 PM
72hardtop The following chart shows CHT, EGT etc...and relat... May 18 2014, 01:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 02:12 PM |
