> Running Hot on the Highway
NJ914Guy
post Jul 25 2012, 08:22 PM
My car is a 1973 914 2.0 running dual Weber 40 carbs, an Aircooled.net SVDA vac advance distributor (vac port connected to dual carbs) and a Pertronix electronic ignition module.
Here in NJ, on a 80-90 degree day, the car runs great on the back roads ranging from 30-45 MPH. Using the dip stick temp gauge, she runs around 180-195 for oil temp. If I take her up ont the highway and run the car at 65-80 MPH for 10-20 minutes, the temp will run up to 220-240, based on the outside air temps, which seems too hot.
I assume that since I am fine on the back roads, my flaps and fan are clear and working fine? I do have 100% of the factory tins in place, and from 180-240 degrees, the car runs strong at all temps.
I am thinking that I have a problem and would like to rule out some things. Here's my list of things to try. Please feel free to comment or make additional suggestions.
1. Change oil. I am running 10W-30 now. Have some fresh Brad Penn 20W-50 on hand. Could an oil change help?
2. Drop the oil screen and check for any sludge or blockage which may be impacting oil flow.
3. Check timing on the SVDA dizzy. I am wondering if it's advancing a little too much on the highway? Per John's instruction, when we installed the dizzy we set timing to: 38-45 Total Advance (hose connected) @ 3500 RPM.
4. Pull spark plugs and check for lean conditions.
5. Check carbs and idle jets. Not sure what's in there, but I hear that I want idle jets of 50.
MikeM
post Jul 26 2012, 02:07 PM
Sorry about the hi-jack...
Chris, you run Brad Penn 10/30? How does that work as far as oil pressure and leaks? Any difference between that and 20/50?
Will my engine run cooler with 10/30?
Thanks,
Mike
ChrisFoley
post Jul 26 2012, 03:00 PM
I am Tangerine Racing
QUOTE(MikeM @ Jul 26 2012, 03:07 PM) *
Thanks,
Mike
I was running Brad Penn 20/50 based on the recomendation of Jake Raby, but after some in-depth reading online, I decided to try 10/30. Now I'm convinced that, for most of us northerners at least, 10/30 or 10/40 may be better year round, than 20/50 ever.
Some people think the thicker oil bypasses the cooler more readily, so they use lower viscosity oils and claim their temps are cooler as a result.
20/50 seems to make the pressure too high until the oil is very hot. Well my engine doesn't get that hot except when I beat on it for long intervals, or let it idle for a long time.
10/30 only seems to get too thin above 220F in my engine. That's why I'm thinking 10/40 may be a little better.
NJ914Guy   Running Hot on the Highway   Jul 25 2012, 08:22 PM
mrbubblehead   My car is a 1973 914 2.0 running dual Weber 40 ca...   Jul 25 2012, 09:03 PM
Racer Chris   I agree with Doug. I've been using Brad Penn ...   Jul 26 2012, 06:24 AM
NJ914Guy   Guys, here's John's timing settings, copye...   Jul 26 2012, 06:57 AM
Racer Chris   I'd set the timing at 28 btdc, vac advance d...   Jul 26 2012, 07:31 AM
Racer Chris   Should I pick-up a special type of timing gun? ...   Jul 26 2012, 07:36 AM
NJ914Guy   Thank you, Chris!   Jul 26 2012, 08:11 AM
ape914   check your mixture too. lean running by even a sma...   Jul 26 2012, 10:04 AM
NJ914Guy   What's a good range for O2 on a carbed 914?   Jul 26 2012, 11:01 AM
ape914   What's a good range for O2 on a carbed 914? ...   Jul 26 2012, 11:26 AM
Racer Chris   but in cruise a bit on the rich side is ok on an ...   Jul 26 2012, 12:06 PM
r_towle   I would suggest you listen to Chris. Chris has ta...   Jul 26 2012, 12:25 PM
ape914   I would suggest you listen to Chris. Chris has t...   Jul 27 2012, 01:26 PM
r_towle   I would suggest you listen to Chris. Chris has ...   Jul 27 2012, 07:51 PM
Racer Chris   And I talk with my dad a lot. :) He's a PhD ...   Jul 26 2012, 01:30 PM
ape914   And I talk with my dad a lot. :) He's a PhD...   Jul 27 2012, 01:56 PM
Racer Chris   ... Your Dad and my Dad have a lot in common, may...   Jul 27 2012, 03:23 PM
ape914   [quote name='ape914' post='1715722' date='Jul 27 ...   Jul 27 2012, 04:56 PM
ape914   ... Your Dad and my Dad have a lot in common, ma...   Jul 28 2012, 09:21 AM
MikeM   Sorry about the hi-jack... Chris, you run Brad Pen...   Jul 26 2012, 02:07 PM
Racer Chris   Sorry about the hi-jack... Chris, you run Brad Pe...   Jul 26 2012, 03:00 PM
MikeM   Thanks Chris...I'm going to try Valvoline VR1 ...   Jul 26 2012, 03:22 PM
The Cabinetmaker   The valvoline no longer has zinc in it, IIRC   Jul 26 2012, 03:30 PM
MikeM   Damn...not even the Vr1?   Jul 26 2012, 03:31 PM
SLITS   Want oil .... The "new" Kendall Gt-1 oil...   Jul 26 2012, 03:40 PM
MikeM   Probably not available in my area...   Jul 26 2012, 03:43 PM
Racer Chris   There are some motorcycle oils that still contain ...   Jul 26 2012, 04:02 PM
bembry   1. What is the safe range for oil temps? Is 240 ...   Jul 26 2012, 05:32 PM
mrholland2   Zinc? Do we really need zinc on a fully rebuild m...   Jul 26 2012, 06:03 PM
Racer Chris   Zinc? Do we really need zinc on a fully rebuild ...   Jul 26 2012, 07:15 PM
mrholland2   I've asked for oil with zinc and I get looked ...   Jul 26 2012, 08:05 PM
jcd914   I've asked for oil with zinc and I get looked...   Jul 26 2012, 11:39 PM
Rand   Zinc? Do we really need zinc on a fully rebuild ...   Jul 26 2012, 11:29 PM
wingnut86   I agree with Rich's take on Chris as well. Pl...   Jul 26 2012, 09:29 PM
ape914   I agree with Rich's take on Chris as well. P...   Jul 27 2012, 02:03 PM
kerensky   If I can't find oil with zinc, can I just scra...   Jul 26 2012, 11:21 PM
Rand   If I can't find oil with zinc, can I just scr...   Jul 26 2012, 11:30 PM
Rand   FWIW, there are some oils left. I've rambled a...   Jul 26 2012, 11:28 PM
bembry   :miles: :miles: :miles:   Jul 27 2012, 07:12 PM
mrbubblehead   i am running the amsoil hot rod 5/30wt- zinc fort...   Jul 27 2012, 07:40 PM
Woody   Ape who are you? What are your credentials? All yo...   Jul 27 2012, 08:58 PM
ape914   Ape who are you? What are your credentials? All y...   Jul 28 2012, 09:16 AM
The Cabinetmaker   He's our thread locker. Whenever an informativ...   Jul 27 2012, 09:12 PM
ape914   He's our thread locker. Whenever an informati...   Jul 30 2012, 12:39 PM
mrholland2   Here's my question now: Of the total "oi...   Jul 27 2012, 09:18 PM
wingnut86   Wow. Talk about going "Ape-Shit" Also...   Jul 27 2012, 09:31 PM
mrholland2   *sighs* best thing to do with that type is ignore...   Jul 27 2012, 09:33 PM
tradisrad   How can we get both power and lean burn out of our...   Jul 28 2012, 12:43 PM
Dave_Darling   If my understanding is correct, peak EGTs would be...   Jul 28 2012, 01:39 PM
tradisrad   Dave, You are right about comparing the Honda to t...   Jul 28 2012, 02:57 PM
mrbubblehead   Is it possible for the OP to set his carbs to r...   Jul 28 2012, 05:36 PM
ape914   Is it possible for the OP to set his carbs to ...   Jul 28 2012, 05:49 PM
tradisrad   yes, that is the best thing about weber idf's...   Jul 28 2012, 06:50 PM
ape914   [quote name='mrbubblehead' post='1716193' date='J...   Jul 30 2012, 12:17 PM
r_towle   Is it possible for the OP to set his carbs to ...   Jul 30 2012, 12:51 PM
ape914   [quote name='mrbubblehead' post='1716193' date='J...   Jul 30 2012, 01:39 PM
ape914   from what i know about lean burning and aero engin...   Jul 28 2012, 03:26 PM
ape914   One other thing that can be added to the tunning t...   Jul 30 2012, 12:10 PM
Racer Chris   No different, I got the procedure from mrbubblehea...   Jul 30 2012, 01:41 PM
72hardtop   The following chart shows CHT, EGT etc...and relat...   May 18 2014, 01:10 PM
- Lo-Fi Version Time is now: 23rd November 2026 - 02:13 PM
