> Running Hot on the Highway
NJ914Guy
post Jul 25 2012, 08:22 PM
My car is a 1973 914 2.0 running dual Weber 40 carbs, an Aircooled.net SVDA vac advance distributor (vac port connected to dual carbs) and a Pertronix electronic ignition module.
Here in NJ, on a 80-90 degree day, the car runs great on the back roads ranging from 30-45 MPH. Using the dip stick temp gauge, she runs around 180-195 for oil temp. If I take her up ont the highway and run the car at 65-80 MPH for 10-20 minutes, the temp will run up to 220-240, based on the outside air temps, which seems too hot.
I assume that since I am fine on the back roads, my flaps and fan are clear and working fine? I do have 100% of the factory tins in place, and from 180-240 degrees, the car runs strong at all temps.
I am thinking that I have a problem and would like to rule out some things. Here's my list of things to try. Please feel free to comment or make additional suggestions.
1. Change oil. I am running 10W-30 now. Have some fresh Brad Penn 20W-50 on hand. Could an oil change help?
2. Drop the oil screen and check for any sludge or blockage which may be impacting oil flow.
3. Check timing on the SVDA dizzy. I am wondering if it's advancing a little too much on the highway? Per John's instruction, when we installed the dizzy we set timing to: 38-45 Total Advance (hose connected) @ 3500 RPM.
4. Pull spark plugs and check for lean conditions.
5. Check carbs and idle jets. Not sure what's in there, but I hear that I want idle jets of 50.
ChrisFoley
post Jul 26 2012, 01:30 PM
I am Tangerine Racing
And I talk with my dad a lot. (IMG:style_emoticons/default/smile.gif)
He's a PhD aerospace engineer and has more than 60 years experience flying small planes with aircooled engines. He tends to maintain a larger safety margin than I do. (IMG:style_emoticons/default/biggrin.gif)
ape914
post Jul 27 2012, 01:56 PM
red locktite
Group: Retired Members
QUOTE(Racer Chris @ Jul 26 2012, 12:30 PM) *
I talked to my Dad last night.
Aerospace engineeer, not a pilot, but he works on stuff that goes a lot higher (past edge of solar system) He has had plenty of experience as a test enginner for all sorts of fixxed wing and rotor craft. He does car stuff to on the side, including thermal testing of components for Telsa cars. Oh and he has been an aircooled motor mechanic since 1958 as a hobby.
Your Dad and my Dad have a lot in common, maybe yours can take my Dad flying sometime.
Oh this is so warm and fuzzy, feels like family.
ChrisFoley
post Jul 27 2012, 03:23 PM
QUOTE(ape914 @ Jul 27 2012, 02:56 PM) *
(IMG:style_emoticons/default/grouphug.gif)
Just stop by my shop sometime with your Dad.
If my dad's not travelling, there's a good chance he'll be nearby.
He loves to show off his Ryan STA restoration project in the corner of my shop, and his Bonanza is hangared only 15 minutes away.
If you don't live anywhere near Hartford, don't let that stop you.
Elliot Cannon was here from CA, and Mary Shortridge flew in from Kansas with her father and uncle for a visit.
BTW, I'm nowhere near 100 years old. My dad is only 83. (IMG:style_emoticons/default/bye1.gif)
What did one firecracker say to the other?
My pop's bigger than your pop!
(IMG:style_emoticons/default/blowup.gif) (IMG:style_emoticons/default/happy11.gif)
But seriously,
If one has adequate instrumentation and knows what to shoot for, lean cruising with carbs or FI is an excellent choice for cool temps combined with great fuel mileage.
Here's a little light reading on the subject: Mixture Management and Cylinder Head Temperatures
ape914
post Jul 27 2012, 04:56 PM
red locktite
QUOTE(Racer Chris @ Jul 27 2012, 02:23 PM) *
But seriously,
So, how does mixture affect cht’s? Here is Lycoming’s chart showing, in a general sense, how mixture, egt, cht and power are related:
Well a bit of data is better than the daddy bragging, or mindless parroting.
The refereanced chart shows cool running at rich mixutes and in lean, but at rich mixtures power is higher. So have it either way, trade off either way.
Although engineers may not always agree, both are generally right.
As for Parrots who post with no first hand knowledge. Parrots are just bird brains. I object to someone saying to listen to some opinion over another becuase in part, his instrument are ASSumed better while not knowing anything about the instruments, nor technique used by the other party, or claiming that only one view point is backed by someone that cares about these issues, impling the other party does not care. Bird brained logic at work if you listen to parrots.
NJ914Guy   Running Hot on the Highway   Jul 25 2012, 08:22 PM
mrbubblehead   My car is a 1973 914 2.0 running dual Weber 40 ca...   Jul 25 2012, 09:03 PM
Racer Chris   I agree with Doug. I've been using Brad Penn ...   Jul 26 2012, 06:24 AM
NJ914Guy   Guys, here's John's timing settings, copye...   Jul 26 2012, 06:57 AM
Racer Chris   I'd set the timing at 28 btdc, vac advance d...   Jul 26 2012, 07:31 AM
Racer Chris   Should I pick-up a special type of timing gun? ...   Jul 26 2012, 07:36 AM
NJ914Guy   Thank you, Chris!   Jul 26 2012, 08:11 AM
ape914   check your mixture too. lean running by even a sma...   Jul 26 2012, 10:04 AM
NJ914Guy   What's a good range for O2 on a carbed 914?   Jul 26 2012, 11:01 AM
ape914   What's a good range for O2 on a carbed 914? ...   Jul 26 2012, 11:26 AM
Racer Chris   but in cruise a bit on the rich side is ok on an ...   Jul 26 2012, 12:06 PM
r_towle   I would suggest you listen to Chris. Chris has ta...   Jul 26 2012, 12:25 PM
ape914   I would suggest you listen to Chris. Chris has t...   Jul 27 2012, 01:26 PM
r_towle   I would suggest you listen to Chris. Chris has ...   Jul 27 2012, 07:51 PM
Racer Chris   And I talk with my dad a lot. :) He's a PhD ...   Jul 26 2012, 01:30 PM
ape914   And I talk with my dad a lot. :) He's a PhD...   Jul 27 2012, 01:56 PM
Racer Chris   ... Your Dad and my Dad have a lot in common, may...   Jul 27 2012, 03:23 PM
ape914   [quote name='ape914' post='1715722' date='Jul 27 ...   Jul 27 2012, 04:56 PM
ape914   ... Your Dad and my Dad have a lot in common, ma...   Jul 28 2012, 09:21 AM
MikeM   Sorry about the hi-jack... Chris, you run Brad Pen...   Jul 26 2012, 02:07 PM
Racer Chris   Sorry about the hi-jack... Chris, you run Brad Pe...   Jul 26 2012, 03:00 PM
MikeM   Thanks Chris...I'm going to try Valvoline VR1 ...   Jul 26 2012, 03:22 PM
The Cabinetmaker   The valvoline no longer has zinc in it, IIRC   Jul 26 2012, 03:30 PM
MikeM   Damn...not even the Vr1?   Jul 26 2012, 03:31 PM
SLITS   Want oil .... The "new" Kendall Gt-1 oil...   Jul 26 2012, 03:40 PM
MikeM   Probably not available in my area...   Jul 26 2012, 03:43 PM
Racer Chris   There are some motorcycle oils that still contain ...   Jul 26 2012, 04:02 PM
bembry   1. What is the safe range for oil temps? Is 240 ...   Jul 26 2012, 05:32 PM
mrholland2   Zinc? Do we really need zinc on a fully rebuild m...   Jul 26 2012, 06:03 PM
Racer Chris   Zinc? Do we really need zinc on a fully rebuild ...   Jul 26 2012, 07:15 PM
mrholland2   I've asked for oil with zinc and I get looked ...   Jul 26 2012, 08:05 PM
jcd914   I've asked for oil with zinc and I get looked...   Jul 26 2012, 11:39 PM
Rand   Zinc? Do we really need zinc on a fully rebuild ...   Jul 26 2012, 11:29 PM
wingnut86   I agree with Rich's take on Chris as well. Pl...   Jul 26 2012, 09:29 PM
ape914   I agree with Rich's take on Chris as well. P...   Jul 27 2012, 02:03 PM
kerensky   If I can't find oil with zinc, can I just scra...   Jul 26 2012, 11:21 PM
Rand   If I can't find oil with zinc, can I just scr...   Jul 26 2012, 11:30 PM
Rand   FWIW, there are some oils left. I've rambled a...   Jul 26 2012, 11:28 PM
bembry   :miles: :miles: :miles:   Jul 27 2012, 07:12 PM
mrbubblehead   i am running the amsoil hot rod 5/30wt- zinc fort...   Jul 27 2012, 07:40 PM
Woody   Ape who are you? What are your credentials? All yo...   Jul 27 2012, 08:58 PM
ape914   Ape who are you? What are your credentials? All y...   Jul 28 2012, 09:16 AM
The Cabinetmaker   He's our thread locker. Whenever an informativ...   Jul 27 2012, 09:12 PM
ape914   He's our thread locker. Whenever an informati...   Jul 30 2012, 12:39 PM
mrholland2   Here's my question now: Of the total "oi...   Jul 27 2012, 09:18 PM
wingnut86   Wow. Talk about going "Ape-Shit" Also...   Jul 27 2012, 09:31 PM
mrholland2   *sighs* best thing to do with that type is ignore...   Jul 27 2012, 09:33 PM
tradisrad   How can we get both power and lean burn out of our...   Jul 28 2012, 12:43 PM
Dave_Darling   If my understanding is correct, peak EGTs would be...   Jul 28 2012, 01:39 PM
tradisrad   Dave, You are right about comparing the Honda to t...   Jul 28 2012, 02:57 PM
mrbubblehead   Is it possible for the OP to set his carbs to r...   Jul 28 2012, 05:36 PM
ape914   Is it possible for the OP to set his carbs to ...   Jul 28 2012, 05:49 PM
tradisrad   yes, that is the best thing about weber idf's...   Jul 28 2012, 06:50 PM
ape914   [quote name='mrbubblehead' post='1716193' date='J...   Jul 30 2012, 12:17 PM
r_towle   Is it possible for the OP to set his carbs to ...   Jul 30 2012, 12:51 PM
ape914   [quote name='mrbubblehead' post='1716193' date='J...   Jul 30 2012, 01:39 PM
ape914   from what i know about lean burning and aero engin...   Jul 28 2012, 03:26 PM
ape914   One other thing that can be added to the tunning t...   Jul 30 2012, 12:10 PM
Racer Chris   No different, I got the procedure from mrbubblehea...   Jul 30 2012, 01:41 PM
72hardtop   The following chart shows CHT, EGT etc...and relat...   May 18 2014, 01:10 PM
- Lo-Fi Version Time is now: 23rd November 2026 - 02:13 PM
