| NJ914Guy |
Jul 25 2012, 08:22 PM
Member ![]() ![]() Group: Members Posts: 150 Joined: 30-December 10 From: Deptford, NJ Member No.: 12,546 Region Association: MidAtlantic Region |
My car is a 1973 914 2.0 running dual Weber 40 carbs, an Aircooled.net SVDA vac advance distributor (vac port connected to dual carbs) and a Pertronix electronic ignition module.
Here in NJ, on a 80-90 degree day, the car runs great on the back roads ranging from 30-45 MPH. Using the dip stick temp gauge, she runs around 180-195 for oil temp. If I take her up ont the highway and run the car at 65-80 MPH for 10-20 minutes, the temp will run up to 220-240, based on the outside air temps, which seems too hot. I assume that since I am fine on the back roads, my flaps and fan are clear and working fine? I do have 100% of the factory tins in place, and from 180-240 degrees, the car runs strong at all temps. I am thinking that I have a problem and would like to rule out some things. Here's my list of things to try. Please feel free to comment or make additional suggestions. 1. Change oil. I am running 10W-30 now. Have some fresh Brad Penn 20W-50 on hand. Could an oil change help? 2. Drop the oil screen and check for any sludge or blockage which may be impacting oil flow. 3. Check timing on the SVDA dizzy. I am wondering if it's advancing a little too much on the highway? Per John's instruction, when we installed the dizzy we set timing to: 38-45 Total Advance (hose connected) @ 3500 RPM. 4. Pull spark plugs and check for lean conditions. 5. Check carbs and idle jets. Not sure what's in there, but I hear that I want idle jets of 50. |
| tradisrad |
Jul 28 2012, 02:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
Dave, You are right about comparing the Honda to the VW engine; they are two different fruits. Some Hondas are designed to run lean utilizing the v-tech technology and the wide-band O2. But as far as I know, which may not be much, the VW engine is not designed to run lean.
My main confusion with this thread is that now I am reading that it is ok to run lean to reduce oil temps when every other thread tells us to run our 914s on the rich side to reduce oil and head temps. With out the proper monitoring equipment an arbitrary lean mixture is just asking for trouble. Is it possible for the OP to set his carbs to run lean while cruising on the freeway and rich in other driving conditions so he has power? Or does he need to drop hundreds of dollars into monitoring equipment to achieve this? From the OP he is monitoring his oil temp with a dip-stick temp gauge. Not very high tech no expensive. Many guys have added a second oil cooler to help reduce oil temps. Some have even gone as far as changing the entire air cooling system (to the horizontal fan set up) to reduce temps. |
NJ914Guy Running Hot on the Highway Jul 25 2012, 08:22 PM
mrbubblehead
My car is a 1973 914 2.0 running dual Weber 40 ca... Jul 25 2012, 09:03 PM
Racer Chris I agree with Doug.
I've been using Brad Penn ... Jul 26 2012, 06:24 AM
NJ914Guy Guys, here's John's timing settings, copye... Jul 26 2012, 06:57 AM
Racer Chris
I'd set the timing at 28 btdc, vac advance d... Jul 26 2012, 07:31 AM
Racer Chris
Should I pick-up a special type of timing gun?
... Jul 26 2012, 07:36 AM
NJ914Guy Thank you, Chris! Jul 26 2012, 08:11 AM
ape914 check your mixture too. lean running by even a sma... Jul 26 2012, 10:04 AM
NJ914Guy What's a good range for O2 on a carbed 914? Jul 26 2012, 11:01 AM
ape914
... Jul 26 2012, 11:26 AM
Racer Chris
but in cruise a bit on the rich side is ok on an ... Jul 26 2012, 12:06 PM
r_towle I would suggest you listen to Chris.
Chris has ta... Jul 26 2012, 12:25 PM
ape914
Chris has t... Jul 27 2012, 01:26 PM
r_towle
Chris has ... Jul 27 2012, 07:51 PM
Racer Chris And I talk with my dad a lot. :)
He's a PhD ... Jul 26 2012, 01:30 PM
ape914
He's a PhD... Jul 27 2012, 01:56 PM
Racer Chris
Your Dad and my Dad have a lot in common, may... Jul 27 2012, 03:23 PM
ape914
[quote name='ape914' post='1715722' date='Jul 27 ... Jul 27 2012, 04:56 PM
ape914
Your Dad and my Dad have a lot in common, ma... Jul 28 2012, 09:21 AM
MikeM Sorry about the hi-jack...
Chris, you run Brad Pen... Jul 26 2012, 02:07 PM
Racer Chris
Chris, you run Brad Pe... Jul 26 2012, 03:00 PM
MikeM Thanks Chris...I'm going to try Valvoline VR1 ... Jul 26 2012, 03:22 PM
The Cabinetmaker The valvoline no longer has zinc in it, IIRC Jul 26 2012, 03:30 PM
MikeM Damn...not even the Vr1? Jul 26 2012, 03:31 PM
SLITS Want oil .... The "new" Kendall Gt-1 oil... Jul 26 2012, 03:40 PM
MikeM Probably not available in my area... Jul 26 2012, 03:43 PM
Racer Chris There are some motorcycle oils that still contain ... Jul 26 2012, 04:02 PM
bembry 1. What is the safe range for oil temps? Is 240 ... Jul 26 2012, 05:32 PM
mrholland2 Zinc? Do we really need zinc on a fully rebuild m... Jul 26 2012, 06:03 PM
Racer Chris
Zinc? Do we really need zinc on a fully rebuild ... Jul 26 2012, 07:15 PM
mrholland2 I've asked for oil with zinc and I get looked ... Jul 26 2012, 08:05 PM
jcd914
I've asked for oil with zinc and I get looked... Jul 26 2012, 11:39 PM
Rand
Zinc? Do we really need zinc on a fully rebuild ... Jul 26 2012, 11:29 PM
wingnut86 I agree with Rich's take on Chris as well.
Pl... Jul 26 2012, 09:29 PM
ape914
P... Jul 27 2012, 02:03 PM
kerensky If I can't find oil with zinc, can I just scra... Jul 26 2012, 11:21 PM
Rand
If I can't find oil with zinc, can I just scr... Jul 26 2012, 11:30 PM
Rand FWIW, there are some oils left.
I've rambled a... Jul 26 2012, 11:28 PM
bembry :miles: :miles: :miles: Jul 27 2012, 07:12 PM
mrbubblehead i am running the amsoil hot rod 5/30wt- zinc fort... Jul 27 2012, 07:40 PM
Woody Ape who are you? What are your credentials? All yo... Jul 27 2012, 08:58 PM
ape914
Ape who are you? What are your credentials? All y... Jul 28 2012, 09:16 AM
The Cabinetmaker He's our thread locker. Whenever an informativ... Jul 27 2012, 09:12 PM
ape914
He's our thread locker. Whenever an informati... Jul 30 2012, 12:39 PM
mrholland2 Here's my question now: Of the total "oi... Jul 27 2012, 09:18 PM
wingnut86 Wow.
Talk about going "Ape-Shit"
Also... Jul 27 2012, 09:31 PM
mrholland2 *sighs* best thing to do with that type is ignore... Jul 27 2012, 09:33 PM
tradisrad How can we get both power and lean burn out of our... Jul 28 2012, 12:43 PM
Dave_Darling If my understanding is correct, peak EGTs would be... Jul 28 2012, 01:39 PM
mrbubblehead
Is it possible for the OP to set his carbs to r... Jul 28 2012, 05:36 PM
ape914
Is it possible for the OP to set his carbs to ... Jul 28 2012, 05:49 PM
tradisrad
yes, that is the best thing about weber idf's... Jul 28 2012, 06:50 PM
ape914
[quote name='mrbubblehead' post='1716193' date='J... Jul 30 2012, 12:17 PM
r_towle
Is it possible for the OP to set his carbs to ... Jul 30 2012, 12:51 PM
ape914
[quote name='mrbubblehead' post='1716193' date='J... Jul 30 2012, 01:39 PM
ape914 from what i know about lean burning and aero engin... Jul 28 2012, 03:26 PM
ape914 One other thing that can be added to the tunning t... Jul 30 2012, 12:10 PM
Racer Chris No different, I got the procedure from mrbubblehea... Jul 30 2012, 01:41 PM
72hardtop The following chart shows CHT, EGT etc...and relat... May 18 2014, 01:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 02:13 PM |
