Crazy LT1 waterpump idea, Shoehorning an LT1 into a 914! |
bondo |
Jun 4 2004, 11:18 AM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
As some of you already know, I'm doing a V8 conversion in my 914 with an LT1 from a 1993 firebird. The cam driven waterpump sticks out the front and gets in the way in a big way. In order to avoid extreme firewall modifications, I came up with a crazy idea... I'll install an electric waterpump kit in the stock waterpump housing... and mount the sucker up by the radiator! It will require a couple of custom flanges, and a couple hose "Ys" but it should work.. with one possible exception. The thermostat is in the water pump, and it's a fancy bypass thermostat. instead of blocking the water until it warms up, it bypasses the radiator until it warms up, and once it warms up it closes the bypass and opens the radiator. I'm worried that the engine may overheat before the thermostat has a chance to open, because it's farther away and will react later than usual. Has anyone ever done anything even remotely like this? Am I nuts?
--Royce |
John Kelly |
Jun 5 2004, 07:24 AM
Senior Member Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
Not sure what kind of room you might need, but it is possible to stretch the bulkhead (a lot if necessary) with very simple tools...depends on where and how much of course. You could stretch the metal 2"-3" out of your way if there is room in the cockpit for the bulge. See this album:
http://allshops.org/cgi-bin/community/comm...d=9980138836765 and this one: http://allshops.org/cgi-bin/community/comm...d=9980160442904 John www.ghiaspecialties.com |
Lo-Fi Version | Time is now: 6th June 2024 - 06:00 PM |
