AX tire pressure vs. tread roll, kumho V710 |
mskala |
Aug 11 2012, 03:40 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Question is this for autocross purposes: If I'm running 24PSI hot and the
tread wear triangles are still not touched, should I go lower? My thought is that either: 1) lower pressure will improve the contact patch and more grip will improve my time. or 2) lower pressure will make slaloms slower by having more flex/lean in the car which will increase my time. Using Kumho V710 215/40/16 on a 7.5" rim on my narrow -6. 21mm torsion bars in front and 180 pound springs in the rear, because that's as high as I want to go and still be driving this thing on the street regularly. Appreciate any input. Mark S. |
DanT |
Aug 11 2012, 11:02 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Your car is very soft in the rear.
As far as pressures... On my orange RaceCar with the 2056 motor I ran V710 in 205x50x15 on 7" wheels.. I ran them 24psi hot. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:54 AM |
