> My First Setback - SUCCESS!, Looks like a bad starter or solenoid
turk22
post Aug 12 2012, 05:28 PM
Treetop Flyer
Hey, so it seems like my starter may have crapped out. Worst part is I think its my fault. I went to start the car, the car was in gear, and it engaged, the car moved forward a little (an inch), and I immediately let off the key. Since that moment, when trying to start, I get a loud click from the starter (or the relay?), but nothing else.
After looking at all the related threads, here's what I've done to test:
- Tried to jump the starter from the yellow wire terminal on the solenoid to the positive on the starter with a screwdriver, just got a weak spark, and the starter did nothing.
- Tried to jump the starter from the positive to the negative side with a jumper cable (If I understand correctly the starter should spin, but the flywheel not engage?). Nothing happened, not a sound, click, or anything.
From what I've been reading it seems like a bad starter.
I know there is probably more to test/eliminate to make sure this is starter issue. But electrical is not my strong suit. I have purchased a multimeter.
- I believe that I need to test the voltage from the yellow lead of the solenoid while cranking the engine. Question: Just ground the meter to the tranny case?
The car was starting fine, and after that one incident, never again. I bump started it, and drove around the block a few time (hoping the starter was just stuck or something), but no luck, same click, no start.
What I'm hoping to do, is rule out other possibilites and then I guess order the replacement starter if that's what needed.
Turk
turk22
post Aug 12 2012, 09:02 PM
Treetop Flyer
Thanks I'll give that a try, its not possible that it could still be stuck after bump starting it a couple of times is it??
turk22   My First Setback - SUCCESS!   Aug 12 2012, 05:28 PM
mrbubblehead   i would suggest that you pull it out and bench tes...   Aug 12 2012, 05:58 PM
turk22   Thanks I'll give that a try, its not possible ...   Aug 12 2012, 09:02 PM
turk22   All, Any advice on what to check prior to pullin...   Aug 13 2012, 01:23 PM
Drums66   .....I'm in alinement with what's been s...   Aug 13 2012, 01:42 PM
Jon H.   Check your grounds first, starting at the battery,...   Aug 13 2012, 04:13 PM
zeezee   I had just put a new starter in and for a month it...   Aug 13 2012, 05:10 PM
SUNAB914   bang the starter with a hammer first, maybe that w...   Aug 14 2012, 08:10 AM
turk22   So I want to puke a little... :barf: I replaced...   Aug 16 2012, 05:58 PM
rnellums   I would check the transmission ground strap first,...   Aug 17 2012, 07:38 AM
Cap'n Krusty   Hey, so it seems like my starter may have crapped...   Aug 17 2012, 08:18 AM
SLITS   John's correct. If you look at a solenoid the...   Aug 17 2012, 08:55 AM
turk22   Thanks guys, I'm really trying to understand...   Aug 17 2012, 10:29 AM
SLITS   All those things are correct, but you would only h...   Aug 17 2012, 10:36 AM
Jeff Bowlsby   "run a jumper cable from the negative post on...   Aug 17 2012, 10:36 AM
turk22   "run a jumper cable from the negative post o...   Aug 17 2012, 10:46 AM
Cap'n Krusty   "run a jumper cable from the negative post ...   Aug 17 2012, 01:05 PM
turk22   I would check the transmission ground strap first...   Aug 17 2012, 01:13 PM
turk22   Well not much success today: I put the battery on...   Aug 17 2012, 05:59 PM
rnellums   If I wasn't in St. Louis right now I would swi...   Aug 17 2012, 10:04 PM
SLITS   The VOM should have long enough leads that you sho...   Aug 18 2012, 08:48 AM
turk22   Well, a fellow 914World member (thanks again toads...   Aug 19 2012, 09:28 AM
Jon H.   Have you tried to jump start the car or at least m...   Aug 19 2012, 07:08 PM
zambezi   Have you tried to jump start the car or at least ...   Aug 19 2012, 07:43 PM
turk22   SUCCESS!!! :cheer: I replaced the po...   Aug 20 2012, 03:34 PM
toadman   SUCCESS!!! :cheer: I replaced the p...   Aug 20 2012, 06:23 PM
dlee6204   :trophy: :driving:   Aug 20 2012, 04:50 PM
turk22   Yep, I was just out for a nice drive, what beautif...   Aug 20 2012, 05:58 PM
76-914   Did you prep and seal that cable end and those rin...   Aug 20 2012, 06:56 PM
turk22   Did you prep and seal that cable end and those ri...   Aug 20 2012, 07:29 PM
- Lo-Fi Version Time is now: 30th April 2026 - 05:28 AM
