Daiberl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 574 Joined: 22-June 09 From: Seattle, WA Member No.: 10,497 Region Association: Pacific Northwest ![]() |
Hello,
I need some help, I finally fixed all my vacuum leaks, the car idles fine, have a Hot Spark installed, and timing seems to be OK. Today I drove the car a bit and after a while the temp gauge indicated that the car is running hot, the needle moved over the P of TEMP before I decided to stop and take a break. After 30 minutes I started the car again and drive immediately home, needle again indicated that the car is running to hot. Before I fixed all vaccum leaks the car was running like ... but the temp stayed consistent in the middle, so I assume the gauge is fine. What to check, the knob on the ECU is already all the way to rich. - Juergen |
Daiberl |
I will have time again on Wednesday to work on the car (btw, it's a 1974 LE with matching engine), I have to fly to Chicago utnil tomorrow evening so no Teener wrenching. Advance port on distributor is connected, retard not just as it was from factory. Distributor is rebuild with brand new points, ... Plan is now:
poorsche914 |
T4 Supercharged ![]() ![]() ![]() ![]() Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States ![]() |
... (btw, it's a 1974 LE with matching engine) ... If you haven't already, be sure to have Jeff Bowlsby add it to the Can Am Registry (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 08:34 PM |
