| turk22 |
Aug 12 2012, 05:28 PM
Treetop Flyer ![]() ![]() ![]() Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
Hey, so it seems like my starter may have crapped out. Worst part is I think its my fault. I went to start the car, the car was in gear, and it engaged, the car moved forward a little (an inch), and I immediately let off the key. Since that moment, when trying to start, I get a loud click from the starter (or the relay?), but nothing else.
After looking at all the related threads, here's what I've done to test: - Tried to jump the starter from the yellow wire terminal on the solenoid to the positive on the starter with a screwdriver, just got a weak spark, and the starter did nothing. - Tried to jump the starter from the positive to the negative side with a jumper cable (If I understand correctly the starter should spin, but the flywheel not engage?). Nothing happened, not a sound, click, or anything. From what I've been reading it seems like a bad starter. I know there is probably more to test/eliminate to make sure this is starter issue. But electrical is not my strong suit. I have purchased a multimeter. - I believe that I need to test the voltage from the yellow lead of the solenoid while cranking the engine. Question: Just ground the meter to the tranny case? The car was starting fine, and after that one incident, never again. I bump started it, and drove around the block a few time (hoping the starter was just stuck or something), but no luck, same click, no start. What I'm hoping to do, is rule out other possibilites and then I guess order the replacement starter if that's what needed. Turk |
| zeezee |
Aug 13 2012, 05:10 PM
Member ![]() ![]() Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
I had just put a new starter in and for a month it worked great.
One morning I get just a loud "clunk". It took about a dozen real quick/successive twists of the key and "clucks" before it broke free and started up. It's been a month - no repeats ... keeping fingers crossed. |
turk22 My First Setback - SUCCESS! Aug 12 2012, 05:28 PM
mrbubblehead i would suggest that you pull it out and bench tes... Aug 12 2012, 05:58 PM
turk22 Thanks I'll give that a try, its not possible ... Aug 12 2012, 09:02 PM
turk22 All,
Any advice on what to check prior to pullin... Aug 13 2012, 01:23 PM
Drums66 .....I'm in alinement with what's been s... Aug 13 2012, 01:42 PM
Jon H. Check your grounds first, starting at the battery,... Aug 13 2012, 04:13 PM
SUNAB914 bang the starter with a hammer first, maybe that w... Aug 14 2012, 08:10 AM
turk22 So I want to puke a little... :barf:
I replaced... Aug 16 2012, 05:58 PM
rnellums I would check the transmission ground strap first,... Aug 17 2012, 07:38 AM
Cap'n Krusty
Hey, so it seems like my starter may have crapped... Aug 17 2012, 08:18 AM
SLITS John's correct. If you look at a solenoid the... Aug 17 2012, 08:55 AM
turk22 Thanks guys,
I'm really trying to understand... Aug 17 2012, 10:29 AM
SLITS All those things are correct, but you would only h... Aug 17 2012, 10:36 AM
Jeff Bowlsby "run a jumper cable from the negative post on... Aug 17 2012, 10:36 AM
turk22
"run a jumper cable from the negative post o... Aug 17 2012, 10:46 AM
Cap'n Krusty
"run a jumper cable from the negative post ... Aug 17 2012, 01:05 PM
turk22
I would check the transmission ground strap first... Aug 17 2012, 01:13 PM
turk22 Well not much success today:
I put the battery on... Aug 17 2012, 05:59 PM
rnellums If I wasn't in St. Louis right now I would swi... Aug 17 2012, 10:04 PM
SLITS The VOM should have long enough leads that you sho... Aug 18 2012, 08:48 AM
turk22 Well, a fellow 914World member (thanks again toads... Aug 19 2012, 09:28 AM
Jon H. Have you tried to jump start the car or at least m... Aug 19 2012, 07:08 PM
zambezi
Have you tried to jump start the car or at least ... Aug 19 2012, 07:43 PM
turk22 SUCCESS!!! :cheer:
I replaced the po... Aug 20 2012, 03:34 PM
toadman
SUCCESS!!! :cheer:
I replaced the p... Aug 20 2012, 06:23 PM
dlee6204 :trophy: :driving: Aug 20 2012, 04:50 PM
turk22 Yep, I was just out for a nice drive, what beautif... Aug 20 2012, 05:58 PM
76-914 Did you prep and seal that cable end and those rin... Aug 20 2012, 06:56 PM
turk22
Did you prep and seal that cable end and those ri... Aug 20 2012, 07:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 06:30 AM |
