> My First Setback - SUCCESS!, Looks like a bad starter or solenoid
turk22
post Aug 12 2012, 05:28 PM
Treetop Flyer
Hey, so it seems like my starter may have crapped out. Worst part is I think its my fault. I went to start the car, the car was in gear, and it engaged, the car moved forward a little (an inch), and I immediately let off the key. Since that moment, when trying to start, I get a loud click from the starter (or the relay?), but nothing else.
After looking at all the related threads, here's what I've done to test:
- Tried to jump the starter from the yellow wire terminal on the solenoid to the positive on the starter with a screwdriver, just got a weak spark, and the starter did nothing.
- Tried to jump the starter from the positive to the negative side with a jumper cable (If I understand correctly the starter should spin, but the flywheel not engage?). Nothing happened, not a sound, click, or anything.
From what I've been reading it seems like a bad starter.
I know there is probably more to test/eliminate to make sure this is starter issue. But electrical is not my strong suit. I have purchased a multimeter.
- I believe that I need to test the voltage from the yellow lead of the solenoid while cranking the engine. Question: Just ground the meter to the tranny case?
The car was starting fine, and after that one incident, never again. I bump started it, and drove around the block a few time (hoping the starter was just stuck or something), but no luck, same click, no start.
What I'm hoping to do, is rule out other possibilites and then I guess order the replacement starter if that's what needed.
Turk
turk22
post Aug 17 2012, 10:46 AM
Treetop Flyer
QUOTE(Jeff Bowlsby @ Aug 17 2012, 12:36 PM) *
"run a jumper cable from the negative post on the battery to the lower bolt on the starter. And try to start the car. "
The neg battery post goes direct to ground, not to the starter. The lug bolt on the starter solenoid takes the battery+ cable. Don't jumper the battery- to the starter as you describe, just hook things up like they should be. If you suspect your starter, any FLAPS will test it for you.
thanks Jeff, I was reading in other threads that if you suspect you have a bad ground, to verify that, you would ground directly to the starter bolt (basically bypassing all the other potential grounds) and see if it engages. If it does, then you are pretty sure you have a bad ground, and then you have to find and fix it.
I just purchased a refurb Bosch SR17x starter, so I'm hoping its not the starter. I guess check number three would be to remove the starter and the battery, bring it to AutoZone, and have them test both...
Turk
Cap'n Krusty
post Aug 17 2012, 01:05 PM
Cap'n Krusty
QUOTE(turk22 @ Aug 17 2012, 09:46 AM) *
Turk
The nice folks at most FLAPS, including Autozone, aren't all that good at testing stuff, especially since their main goal is to sell you parts ................
The Cap'n
turk22   My First Setback - SUCCESS!   Aug 12 2012, 05:28 PM
mrbubblehead   i would suggest that you pull it out and bench tes...   Aug 12 2012, 05:58 PM
turk22   Thanks I'll give that a try, its not possible ...   Aug 12 2012, 09:02 PM
turk22   All, Any advice on what to check prior to pullin...   Aug 13 2012, 01:23 PM
Drums66   .....I'm in alinement with what's been s...   Aug 13 2012, 01:42 PM
Jon H.   Check your grounds first, starting at the battery,...   Aug 13 2012, 04:13 PM
zeezee   I had just put a new starter in and for a month it...   Aug 13 2012, 05:10 PM
SUNAB914   bang the starter with a hammer first, maybe that w...   Aug 14 2012, 08:10 AM
turk22   So I want to puke a little... :barf: I replaced...   Aug 16 2012, 05:58 PM
rnellums   I would check the transmission ground strap first,...   Aug 17 2012, 07:38 AM
Cap'n Krusty   Hey, so it seems like my starter may have crapped...   Aug 17 2012, 08:18 AM
SLITS   John's correct. If you look at a solenoid the...   Aug 17 2012, 08:55 AM
turk22   Thanks guys, I'm really trying to understand...   Aug 17 2012, 10:29 AM
SLITS   All those things are correct, but you would only h...   Aug 17 2012, 10:36 AM
Jeff Bowlsby   "run a jumper cable from the negative post on...   Aug 17 2012, 10:36 AM
turk22   "run a jumper cable from the negative post o...   Aug 17 2012, 10:46 AM
Cap'n Krusty   "run a jumper cable from the negative post ...   Aug 17 2012, 01:05 PM
turk22   I would check the transmission ground strap first...   Aug 17 2012, 01:13 PM
turk22   Well not much success today: I put the battery on...   Aug 17 2012, 05:59 PM
rnellums   If I wasn't in St. Louis right now I would swi...   Aug 17 2012, 10:04 PM
SLITS   The VOM should have long enough leads that you sho...   Aug 18 2012, 08:48 AM
turk22   Well, a fellow 914World member (thanks again toads...   Aug 19 2012, 09:28 AM
Jon H.   Have you tried to jump start the car or at least m...   Aug 19 2012, 07:08 PM
zambezi   Have you tried to jump start the car or at least ...   Aug 19 2012, 07:43 PM
turk22   SUCCESS!!! :cheer: I replaced the po...   Aug 20 2012, 03:34 PM
toadman   SUCCESS!!! :cheer: I replaced the p...   Aug 20 2012, 06:23 PM
dlee6204   :trophy: :driving:   Aug 20 2012, 04:50 PM
turk22   Yep, I was just out for a nice drive, what beautif...   Aug 20 2012, 05:58 PM
76-914   Did you prep and seal that cable end and those rin...   Aug 20 2012, 06:56 PM
turk22   Did you prep and seal that cable end and those ri...   Aug 20 2012, 07:29 PM
- Lo-Fi Version Time is now: 30th April 2026 - 05:29 AM
