A/F readings, What do the experts think? |
Black22 |
Aug 19 2012, 04:47 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Hey all,
I've got a 1911cc motor with about 250 miles on it. KB pistons, stock cam and L-jet, with 1.8l heads modified to 2L valve sizes. Compression is 8.5:1. Running Brad Penn 20/50. Car was recently running way rich and got VERY poor gas mileage. I hooked up with Joe Sharp, (thanks again Joe!) and he let me use his LM-1. I tried to dial my L-jet in and got pretty close. I've since purchased and installed an Innovate MTX-L AFR kit. Gauge works great! Here is my readings as of now and after MUCH tweaking this is my dilemma. AFR stats: Idle= 12.7 WOT= 9.7-10.2 (it will hit these readings regardless of RPM) Decel= 14.8-15.9 Timing is set @ 7.5* @ ~900rpm with vacuum ports disconnected and plugged. WOT seem rich still, but now my motor runs hotter. I know I'm leaning the motor out and should expect higher oil temps but I was running about 190-200 and now I'm running 210-220. I'm also running an external 72 plate oil cooler w/fan! I've adjusted the timing to experiment, and had it at 9.5* adv. and it ran cooler at idle but the temp went back up while driving. It seems I have some more adjustments to get it even leaner, but that's just going to raise the temps right? (IMG:style_emoticons/default/confused24.gif) What do you guys think and what should I do (if anything) next? |
ChrisFoley |
Aug 19 2012, 05:41 PM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You should get a CHT gauge.
Leaning out the mixture will have a greater effect on CHT than oil temp. I want my oil to get up to 210F to fully burn off volatile impurities. And I have to work pretty hard to get it that hot. As long as you have at least 10psi per 1K rpm its not too hot. I'm running BP 10/30 in my 1911 with D-Jet. No problem with oil temp/pressure or CHT. I've driven hard on 100 degree days and had no issues. |
Lo-Fi Version | Time is now: 11th June 2024 - 03:21 AM |
