broomhandle |
Member ![]() ![]() Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California ![]() |
I have a 1.8, and it runs like a bus motor, its a EC 1.8. i can be driving and it will be a 914 for a few seconds and then back to a bus...
so, i did a compression test 4= 80-60 3= 100 2= 120 1 = 100 and my plug on no. 4 is black. new plugs. what could be going on? the valves are not adjusted. and also, i feel like its timed right. but, then you drive it.... and it just not timed right... what could be going on with No. 4? and why would No.2 be higher? because its the opposite side? compensate? im a lone 914'er... and Vdubber... you guys are the only people to ask! (IMG:style_emoticons/default/smile.gif) |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
The bad plug, is most likely a failing non firing fuel injector. It explains what he said earlier about the car driving like a porsche sometimes and other times like a bus.
You must adjust your valves, and warm the engine up before doing any compression tests. |
Lo-Fi Version | Time is now: 6th July 2025 - 10:40 PM |
