> Alternator upping amperage suggestions, I already up'd to 75 amps... not enough.
pnewman
post Aug 18 2012, 10:08 PM
Ok Ok Ok.
I have to many gadgets in my car for a 75 amp alternator to support. They all work great but they are pigs:
Heated seats
high power stereo
Sub woofer w/ amp
HID headlights
windshield washer pump
Interior / map lights in rear view mirror
etc.
So I have a seperate circuit and an electrical sub-panel to support the load safely but simply put:
"I need more power Scotty!"
Took my old 50 amp Bosch to an alternator / starter rebuilder and after looking at it a bit they recommended the AC Delco 100 / 105+ amp single wire alternator with integral regulator for $110 rebuilt. He stated that it could run the dash idiot light too.
Not quite ready to bypass the voltage regulator etc.
I am sure this mod is probably old hat for some.
Thoughts?
Thanks in advance, (IMG:style_emoticons/default/driving-girl.gif)
Pete
Mike Bellis
post Aug 19 2012, 09:30 AM
Resident Electrician
I think you should go with the GM alternator. I run a GM style Powermaster 180 Amp unit. There is no advantage to keeping the stock VR unless you intend to concourse the car.
Biggest upgrade for the buck is up sizing all wires. I run a #2 charge wire and have upgraded all grounds. I bet your stereo wiring is bigger than most of the stock 914 wiring. Add extra grounds, bigger wire. Add a ground from the alternator to the battery.
If your amplifier has a 20 amp fuse, that means it can take spikes of current up to 20 amps. The factory alternator charge wire is a #8. This is barely adequate for 20 amps of DC current. The car battery acts like a buffer, not allowing all that current into the battery at one time to recharge. This is mostly due to internal resistance. Your amplifier need instant current flow. Here is the advantage of a charging capcitor. The cap will charge and discharge instantly to help out.
Most people do not realize that DC current takes a bigger conductor than AC current. Because of this, most will quote AC amperage charts. The world realized this and chose Tesla's AC power over Edison's DC power. Edison needed a 4" diameter conductor to push DC down a single block of homes. Tesla only needed a 1/4" conductor for the same distance with AC power.
When I was manager at a car stereo shop (and master installer), we would use #8 amplifier wires at a minimum. We also upgraded the ground from battery to chassis and battery to engine block. This worked well for night time headlight dimming problems.
The wiring and chassis on your 914 is old, rusty and corroded after 40 years. The wiring has reached its life span. The unit body is now grounded through rusty metal and spot welds. Start with upgrading your wiring first.
pnewman
post Aug 21 2012, 10:51 PM
I am concerned about the cleanlyness and reliability of bypassing the VR and am not a fan of splicing into the wiring harness to accomplish the mod. Although I might not have to at all sans the idiot light accomodation.
pnewman   Alternator upping amperage suggestions   Aug 18 2012, 10:08 PM
GeorgeRud   It really should just come down to whether the Del...   Aug 19 2012, 06:51 AM
ArtechnikA   HID headlights HID's actually consume less c...   Aug 19 2012, 07:35 AM
kg6dxn   I think you should go with the GM alternator. I ru...   Aug 19 2012, 09:30 AM
jsayre914   I think you should go with the GM alternator. I r...   Aug 19 2012, 01:43 PM
pnewman   I think you should go with the GM alternator. I ...   Aug 21 2012, 10:49 PM
jsayre914   I like the idea of having a modified or rewound ...   Aug 22 2012, 02:06 PM
pnewman   I am concerned about the cleanlyness and reliabili...   Aug 21 2012, 10:51 PM
pnewman   I think you should go with the GM alternator. I r...   Aug 21 2012, 10:52 PM
kg6dxn   PLEASE SHOW US SOME PICS OF HOW YOU FIT AND SET I...   Aug 23 2012, 02:29 PM
jsayre914   Don't get too excited... I don't have a ...   Aug 23 2012, 03:30 PM
dlestep   The world realized this and chose Tesla's AC...   Aug 22 2012, 02:12 PM
ArtechnikA   [quote name='kg6dxn' post='1725857' date='Aug 19 ...   Aug 22 2012, 02:16 PM
dlestep   [quote name='dlestep' post='1727599' date='Aug 22...   Aug 22 2012, 07:24 PM
pnewman   I think you should go with the GM alternator. I r...   Sep 8 2012, 12:32 PM
Rod   Interested in this too. A friend of mine has just...   Aug 22 2012, 10:31 AM
balljoint   davep was building higher output alternators. Try...   Aug 22 2012, 01:32 PM
pnewman   davep was building higher output alternators. Tr...   Sep 8 2012, 01:21 PM
ArtechnikA   Which leads us to the inevitable question - how d...   Aug 22 2012, 02:14 PM
jsayre914   Which leads us to the inevitable question - how d...   Aug 22 2012, 02:53 PM
Matt Meyer   I don't see why you would ever run a one wire ...   Aug 22 2012, 02:28 PM
pnewman   I don't see why you would ever run a one wire...   Sep 8 2012, 12:10 PM
damesandhotrods   [quote name='pnewman' date='Aug 18 201...   Aug 22 2012, 02:34 PM
Bartlett 914   [quote name='pnewman' date='Aug 18 20...   Aug 22 2012, 03:07 PM
pnewman   Ok Ok Ok. I have to many gadgets in my car for...   Sep 8 2012, 12:07 PM
damesandhotrods   Then why not install an amp meter and monitor your...   Aug 22 2012, 07:20 PM
pnewman   Then why not install an amp meter and monitor you...   Sep 8 2012, 12:21 PM
kg6dxn   The smaller pulley will rob 1-2hp due to spinning ...   Sep 8 2012, 12:18 PM
02loftsmoor   I thought sports cars didn't have all that FLU...   Sep 8 2012, 11:23 PM
pnewman   I thought sports cars didn't have all that FL...   Sep 9 2012, 01:22 PM
balljoint   I thought sports cars didn't have all that F...   Oct 5 2012, 11:54 AM
tim_nd   When you upgrade to this one wire, can I have your...   Sep 9 2012, 12:16 AM
jockellis   In the mid '70s, the owner of a Waycross, GA V...   Sep 9 2012, 06:56 AM
ArtechnikA   Wire costs something and it weighs something. When...   Sep 9 2012, 07:15 AM
pnewman   [b]I have an upgraded 105 amp alternator now with ...   Oct 5 2012, 11:40 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:43 AM
