| solex |
Aug 20 2012, 07:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I have had this problem for some time but cannot determine the cause. The front end rattles particularly when the wheels are turned and I go over a bump.
I had the car jacked up and could not find anything that is obviously loose. I checked the wheel bearings an they are all good. The front dampers look like they can be replaced as they show signs of leaking (a while ago), but the front end is not bouncy. Regards, Dan |
| Eric_Shea |
Aug 25 2012, 07:14 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Normal mode is fully extended on "gas pressurized" struts. Hydraulics can rest in any position. The fact that they collapse and then begin to compress would have me shopping for new inserts.
solex Front End Rattle -- Need Some Ideas [SOLVED] Aug 20 2012, 07:31 AM
Van914 Sway bar Aug 20 2012, 07:45 AM
solex
Sway bar
My car does not have sway bars Aug 20 2012, 07:54 AM
jsconst
Sway bar
That's what was causing my front e... Aug 20 2012, 07:55 AM
dlestep Do you feel it through the steering wheel ?
Check ... Aug 20 2012, 07:58 AM
solex (1) The front end has not been lowered.
(2) I repl... Aug 20 2012, 08:09 AM
matthepcat You might want to try pulling the top strut sleeve... Aug 20 2012, 08:46 AM
SLITS
You might want to try pulling the top strut sleev... Aug 20 2012, 01:44 PM
solex This will involve removing the top of the strut co... Aug 20 2012, 03:13 PM
SLITS
This will involve removing the top of the strut c... Aug 20 2012, 03:20 PM
matthepcat Often you can just unbolt the at the top, tap the ... Aug 20 2012, 03:48 PM
solex Thanks all, it was the strut collar, not sure why ... Aug 25 2012, 06:25 PM
solex will start shopping... Aug 25 2012, 07:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:42 AM |
