| stugray |
Oct 18 2010, 02:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have rebuilt a type IV a couple of times, but I was young & naive.
This will be a 2.0L with stock FI for vintage racing. 1 - How do I hook up the stock fuel pump line(s) to a fuel cell? 2 - are there any Cams other than the stock one that will give me increased performance while still using the stock FI? 3 - What compression ratio should I target? I am working that step right now - CC'ing the heads & setting the deck height. 4 - The CAM thrust bearing has just one side with the thrust plate on it. If I recall, when I upgraded my last 914, the guy at the performance shop gave me TWO with the thrust bearing on it (one for each side). Should I be looking for those? 5 - After splitting the case, there were 2 or 3 "bumps" that needed a little "flattening out" with a file. Can the case be damaged by trying to clean up the nasty spots, or is there a way for me to make sure to get it right? I imagine that the only thing I could do would be to remove all the studs and rub each side over some sandpaper taped down to a very flat surface... Any help is appreciated. Stu |
| Dave_Darling |
Aug 27 2012, 03:56 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,328 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Are the 2.0 heads the ones where it is easy to break through into one of the exhaust stud bores? I know that there is one Type IV head that gets very very thin near the exhaust stud when you fly-cut it a bunch.
--DD |
stugray Engine rebuild, a few questions Oct 18 2010, 02:40 PM
Cupomeat Ok, I'll give it a go and I am sure you will h... Oct 18 2010, 03:01 PM
Bleyseng 2. The absolute best cams for Djet FI are Raby cam... Oct 19 2010, 04:02 AM
stugray Cupomeat,
1 - Still trying to find a legal fuel c... Oct 19 2010, 11:06 AM
Cupomeat
Cupomeat,
1 - Still trying to find a legal fuel ... Oct 19 2010, 11:15 AM
ArtechnikA
1 - Still trying to find a legal fuel cell. It ne... Oct 19 2010, 11:52 AM
Jake Raby
Understand this:
My package INCLUDES ALL the ite... Oct 19 2010, 01:01 PM
stugray ArtechnikA,
Thanks for all the comments
"T... Oct 19 2010, 01:30 PM
ArtechnikA
...there are HUNDREDS of choices out there and ve... Oct 19 2010, 06:13 PM
stugray Jake Raby,
Thanks for the detailed reply.
I have ... Oct 19 2010, 01:33 PM
Jake Raby My team is here to help you, don't worry about... Oct 19 2010, 06:42 PM
stugray Thanks again for the comments.
Here are some pics... Oct 20 2010, 07:02 AM
Jake Raby Get rid of those sodium filled exhaust valves... Oct 20 2010, 07:45 AM
stugray Ok, Jake.
I have new valves and purchased your ra... Jan 21 2012, 12:53 PM
stugray Ok, so what I am learning here is that nobody has ... Jan 23 2012, 08:13 PM
jaxdream
Ok, so what I am learning here is that nobody has... Jan 24 2012, 09:12 AM
Jake Raby
You'd waste your time.. All stock chambers ar... Jan 23 2012, 10:38 PM
stugray Ok Next update:
I have the European Motor Works, ... Aug 26 2012, 06:26 PM
cgnj Hi,
60 cc's is what I got on my rebuilt stock... Aug 26 2012, 07:44 PM
Valy Bringing the heads to 48cc will probably remove th... Aug 26 2012, 08:23 PM
stugray Thanks for the tips.
I will target 50cc if I can ... Aug 27 2012, 12:00 AM
Valy You need big washers to spread the load.
I got min... Aug 27 2012, 10:50 AM
Racer Chris Stu,
A tight deck is much better for efficient com... Aug 27 2012, 11:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 09:29 PM |
