| Daiberl |
Aug 23 2012, 09:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 575 Joined: 22-June 09 From: Seattle, WA Member No.: 10,497 Region Association: Pacific Northwest |
I finally had time to check my LE out and why the car is running hot. The spark plug shows that the car runs lean, adjustment knob at ECU is full rich already. MPS checked and leaks 3.5 down from 10in so based on pbanders fine. No vacuum leaks, flaps at oil cooler are open, timing fine.
What can cause the car to run too lean? Would a wrong CHT cause this, I changed the CHT when I dropped the engine last time and didn't drive the car on longer trips. |
| Daiberl |
Aug 27 2012, 10:19 AM
Ok, finally I had some time yesterday to check the car again, I unplugged TS1 and I rechecked timing and vacuum lines. Car is still running very hot and after 15 minutes my oil temp gauge was showing high oil temp again. Any other ideas???
Attached thumbnail(s) |
| 914itis |
Aug 27 2012, 08:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Ok, finally I had some time yesterday to check the car again, I unplugged TS1 and I rechecked timing and vacuum lines. Car is still running very hot and after 15 minutes my oil temp gauge was showing high oil temp again. Any other ideas??? My oil temp reads the same sometimes in above 90 degree temps. but it takes more than 15 minutes to get there; at least an hour of highway driving. |
Daiberl Car is running too lean Aug 23 2012, 09:44 PM
Dustin The knob on the ecu only adjusts mixture when the ... Aug 24 2012, 01:15 AM
Bartlett 914
I finally had time to check my LE out and why the... Aug 24 2012, 07:41 AM
Jeff Bowlsby TS1 can also be unplugged to give a slight richnes... Aug 24 2012, 09:05 AM
Daiberl
TS1 can also be unplugged to give a slight richne... Aug 24 2012, 11:45 AM
Jeff Bowlsby TS1 is the Air temp on the air plenum Aug 24 2012, 01:31 PM
Jeff Bowlsby Thats a normal oil temp reading for the stock guag... Aug 27 2012, 10:40 AM
JRust Yeah I wouldn't sweat your temps there. I woul... Aug 27 2012, 12:48 PM
Daiberl Ok, then I will give it another try and will repor... Aug 27 2012, 07:01 PM
Dave_Darling Is the cooling system complete? Do you have the f... Aug 27 2012, 09:03 PM
Daiberl
Is the cooling system complete? Do you have the ... Aug 27 2012, 09:44 PM
PancakePorsche I raised my fuel pressure to 32 psi and 2 steps co... Aug 29 2012, 03:30 AM
Racer Chris Oil temp isn't a good indicator of fuel mixtur... Aug 29 2012, 07:41 AM
Bleyseng
I finally had time to check my LE out and why the... Aug 29 2012, 09:12 AM
TJB/914 George Hussey @ AA just fixed my slightly lean eng... Aug 29 2012, 09:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th July 2026 - 07:50 PM |
