> 914World Classifieds Rules
> 914-6 engine stuff-, FS 914-6 engine stuff-
larryM
post Aug 23 2012, 09:18 PM
emoze
long block with starter, FW/clutch is sold to a 91l project (IMG:style_emoticons/default/smile.gif)
Sixer specific items still available - everything you now need to hook up that barnfind 911 block you got for cheap and drive away your 914-6 conversion
Weber 40 IDA setup with PMO Tall Manifolds, all linkage & dual feed hard fuel line and all percolation mods, insulators, etc); new 914-6 oem fuel pump, K&N's with watershields, oem air cleaner housing with K&N, oem Bosch CD ign with blue coil 2.4-2.7 distributor and Nology wires, new valeo IR alternator with housing & 11-blade fan & band; oem 914-6 oil cooler, 911S-alloy Pressure plate and Kennedy stage 3 racing clutch disc, also std 911 clutch & PP; New-in-box 215mm Flywheel, MSD 6A with 2.4-2.7 Distributor with Pertronix; 1-5/8 Triad headers, 2-in-1-out race extractor with new Twister muffler, set of megaphones with Supertrap flanges, Bursch extractor-muffler, oem 914-6 hard line from engine to oil cooler/external thermostat, 911-914-6 engine wiring harness, oem 914-6 top shroud with oem rear surround tin plus repro front & side surrounds; fresh set of DRC "e" cams; and more - prefer to sell it all as one complete package - $4500, local pickup
also have - a 911 oil tank with lines that could be used for a conversion project (I used it to bench run engines); a 911 combo oil gage, new 911 external oil cooler thermostat/valve, etc etc
preferrred contact: - eMail - 2elmo22 at gmail - telephone 530 - 8.8.9 - 8.2.6.8 and ask for "ryan"
(i don't check this World site regularly, so don't P.M.)
. 914-6-GT
brant
post Aug 27 2012, 08:51 PM
Yep...
I'm running a 2.0/6 (actually it is 81mm pistons, since .040 overbore is class legal) on a 1973.5 7R case
drop a small crank in, and you can bring displacement down from 2.4
its the strongest of the mag cases if you want to up the redline to 8k or beyond. The original short stroke.
larryM   914-6 engine stuff-   Aug 23 2012, 09:18 PM
ArtechnikA   Have complete 914-6 engine package... displacemen...   Aug 25 2012, 12:23 PM
6freak   Have complete 914-6 engine package... displaceme...   Aug 27 2012, 08:06 AM
brant   could be a 2.0 I would love to hear the displaceme...   Aug 27 2012, 08:30 AM
carr914   7R Case = 2.4 or 2.7 Stock.   Aug 27 2012, 11:51 AM
ArtechnikA   not as easy as that. if it's a 73.5 7R (early ...   Aug 27 2012, 11:54 AM
brant   Yep... I'm running a 2.0/6 (actually it is 81...   Aug 27 2012, 08:51 PM
larryM   content moved to OP   Aug 29 2012, 12:37 PM
ArtechnikA   These deals always come up when I'm in pre-pro...   Aug 29 2012, 03:59 PM
larryM   yes - for those who already have a six and all t...   Sep 12 2012, 12:31 PM
BKLA   Email sent. :D   Sep 12 2012, 03:24 PM
patrick3000   Looks like a nice engine   Sep 28 2012, 08:27 AM
larryM   bump   Dec 29 2012, 06:50 PM
larryM   bump   Apr 5 2013, 01:08 PM
- Lo-Fi Version Time is now: 9th January 2026 - 04:23 AM
