| ThinAir |
Aug 22 2012, 11:08 PM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
RRC is only a couple of weeks away and I'm beginning to get desperate that I'm not going to be able to drive my 914.
When I posted this, my problem was just that the idle would hunt, but otherwise it drove well. After reading the responses and reviewing Brad Anders' stuff again it made sense that my hunting problem was probably that I was just running lean. I turned the ECU 3 clicks clockwise to see if that would improve things, but it didn't seem to. Well, things have gone from poor to bad. Right now I've got a car that barely idles at all, and when I'm accelerating or driving on the highway it often bucks/misfires. I haven't run it long enough to get it warmed up. I've tested the AAR by pulling the supply hose and it seems to be working. If I remove the AAR output hose the RPMs go up to 1000 so perhaps the AAR isn't opening fully. I've measured the ohms on the CHT at 124 so that's within range, and I've got a brand new 270 ohm resistor inline. I have 3 MPS units that all pass on resistance and vacuum and changing them makes no difference in the behavior. I've also recently replaced the spark plug wires (not to solve this problem, but just because) and I've made sure that they are as far away as possible from the MPS unit. I've also checked every electrical connection that I can find. Sorry that all that is so long - any clue what I should be looking at? I'm beginning to panic (IMG:style_emoticons/default/blink.gif) |
| 76-914 |
Aug 28 2012, 07:55 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,865 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
That fuel filter isn't that difficult to R&R. Drain the tank as much as possible. As you lift each side the rubber isolators will pull up and out. After they're removed the tank will shift about quite easily. Lift the pass side up as much as possible, brace the tank so it doesn't slip down and disconnect the hoses. If you've drained most of the gas out then what's left will be to the drivers side and won't leak out when the hose clamps are removed. Pull the tank; R&R hoses/filter; reassemble. PM me if you still need an ECU. kent
ThinAir Very Rough, Low Idle and Missing - Help! Aug 22 2012, 11:08 PM
tim_nd Have you pulled and inspected your plugs? Aug 22 2012, 11:28 PM
ThinAir
That... Aug 22 2012, 11:39 PM
hot_shoe914 Check the points to while you are at it. Aug 23 2012, 07:04 AM
Philip W.
:agree... Aug 23 2012, 07:56 AM
jsconst The bucking and misfiring at speed might be the co... Aug 23 2012, 08:31 AM
Michael N
The bucking and misfiring at speed might be the c... Aug 24 2012, 08:31 AM
ThinAir
The bucking and misfiring at speed might be the ... Aug 24 2012, 09:19 AM
ThinAir Update: Tonight I pulled all the spark plugs, chec... Aug 24 2012, 12:33 AM
Bartlett 914 I suspect you may have some bad gas. Aug 24 2012, 09:06 AM
The Cabinetmaker Unplug the tps. If it runs better, contact davesp... Aug 24 2012, 09:35 AM
jsayre914
Unplug the tps. If it runs better, contact daves... Aug 24 2012, 12:09 PM
StratPlayer I got a new board from dave and it doesn't fun... Aug 24 2012, 10:12 AM
jsayre914 p.s.
I am dealing with the similar issues, my car... Aug 24 2012, 12:12 PM
tim_nd Go ahead and replace your plugs with some freshy... Aug 24 2012, 12:32 PM
tim_nd I also had slight misses at idle. I replaced the ... Aug 24 2012, 12:48 PM
Philip W.
Bad Gas is ... Aug 24 2012, 02:04 PM
shoguneagle Ernie,
Thought I would drop into your thread and ... Aug 24 2012, 05:51 PM
76-914 :confused: any news? Aug 26 2012, 03:35 PM
ThinAir Well the news is that I keep eliminating things so... Aug 28 2012, 12:14 AM
ThinAir WOOOOOOHOOOOOOO!!!!!!... Aug 28 2012, 10:43 PM
Philip W. Great news, i am not surprised. I have chased my t... Aug 29 2012, 06:48 AM
ThinAir One more thing....
I'm still running the 012 ... Aug 28 2012, 10:51 PM
AZ914 Awesome Ernie!
:Qarl: Aug 29 2012, 07:46 AM
76-914 :thumbsup: Aug 29 2012, 08:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 12:28 AM |
