Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,878 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
I have the opportunity to get this MC for my 911 front end (M calipers) conversion but I'm wondering if this is a 19mm MC (IMG:style_emoticons/default/confused24.gif)
Can anyone confirm what MC this is? Thank you (IMG:style_emoticons/default/beerchug.gif) ![]() ![]() |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
So, do you guys think the 19mm dual circuit master cylinder installed on pre-1977 911s is the ONLY 19 mm master cylinder out there? While this one should be all the clue you need, there are literally hundreds of varieties of 19mm master cylinders fitted to all manner of cars and light trucks, and one easy way to identify an Ate 19mm unit is to look for the number embossed on the body.
The Cap'n |
DEC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 632 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany ![]() ![]() |
So, do you guys think the 19mm dual circuit master cylinder installed on pre-1977 911s is the ONLY 19 mm master cylinder out there? While this one should be all the clue you need, there are literally hundreds of varieties of 19mm master cylinders fitted to all manner of cars and light trucks, and one easy way to identify an Ate 19mm unit is to look for the number embossed on the body. The Cap'n (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 03:10 AM |
