> Car is running too lean, 1974 LE 2.0 running hot - spark plug shows too lean
Daiberl
post Aug 23 2012, 09:44 PM
I finally had time to check my LE out and why the car is running hot. The spark plug shows that the car runs lean, adjustment knob at ECU is full rich already. MPS checked and leaks 3.5 down from 10in so based on pbanders fine. No vacuum leaks, flaps at oil cooler are open, timing fine.
What can cause the car to run too lean? Would a wrong CHT cause this, I changed the CHT when I dropped the engine last time and didn't drive the car on longer trips.
TJB/914
post Aug 29 2012, 09:51 AM
Mid-Engn.
George Hussey @ AA just fixed my slightly lean engine issue with a part I bought from him 10-years ago. I found it in my junk drawer and installed it a few days ago and corrected all lean issues. Check out my post with George on 914-Club site and read what happened. I suspected a lean engine idle at low RPM's & lived with it but after installing a "wehrle" part #039.971.762a that adds 270 ohms to the head temp sensor it increased the duration of injecting with a alightly richer mixture for more power & better idle when fully hot.
Guys, I felt the engine smooth out and run better than ever on my 2.0 liter F.I. Raby # 9550 camshaft with Raby LE-180 heads. Amazing tech advise from George. I understand AA sells them, don't know how much $$ but it worked for me.
Tom
Daiberl   Car is running too lean   Aug 23 2012, 09:44 PM
Dustin   The knob on the ecu only adjusts mixture when the ...   Aug 24 2012, 01:15 AM
Bartlett 914   I finally had time to check my LE out and why the...   Aug 24 2012, 07:41 AM
Jeff Bowlsby   TS1 can also be unplugged to give a slight richnes...   Aug 24 2012, 09:05 AM
Daiberl   TS1 can also be unplugged to give a slight richne...   Aug 24 2012, 11:45 AM
Jeff Bowlsby   TS1 is the Air temp on the air plenum   Aug 24 2012, 01:31 PM
Daiberl   Ok, finally I had some time yesterday to check the...   Aug 27 2012, 10:19 AM
914itis   Ok, finally I had some time yesterday to check th...   Aug 27 2012, 08:18 PM
Jeff Bowlsby   Thats a normal oil temp reading for the stock guag...   Aug 27 2012, 10:40 AM
JRust   Yeah I wouldn't sweat your temps there. I woul...   Aug 27 2012, 12:48 PM
Daiberl   Ok, then I will give it another try and will repor...   Aug 27 2012, 07:01 PM
Dave_Darling   Is the cooling system complete? Do you have the f...   Aug 27 2012, 09:03 PM
Daiberl   Is the cooling system complete? Do you have the ...   Aug 27 2012, 09:44 PM
PancakePorsche   I raised my fuel pressure to 32 psi and 2 steps co...   Aug 29 2012, 03:30 AM
Racer Chris   Oil temp isn't a good indicator of fuel mixtur...   Aug 29 2012, 07:41 AM
Bleyseng   I finally had time to check my LE out and why the...   Aug 29 2012, 09:12 AM
TJB/914   George Hussey @ AA just fixed my slightly lean eng...   Aug 29 2012, 09:51 AM
- Lo-Fi Version Time is now: 10th July 2026 - 07:50 PM
