| kbrunk1 |
Aug 29 2012, 10:32 PM
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
OK my MC is leaking at the piston side.
Do most folks go with the $100 19mm MC or pay more for the 17mm one? I assume you can not get rebuild kits for the 17mm correct? I kind of like the idea of keeping the 17mm one but am on a tight budget. Thanks Ken |
| shoguneagle |
Aug 30 2012, 05:37 PM
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
My thoughts go directly to who made the master cylinders. If made in China, you only seem to get cheapness, not quality and durability. I like OEM brands such as ATE.
Within the above confinements, I think the size depends on your brakes you are running as your preference. Normal 914 brakes I like either the 17mm or 19mm, preferring the 17mm (ran these under normal configuration). When I converted the front brakes to 911 Carrera and normal 914 rear brakes, I used the 19mm. At the time I preferred a strong pedal requiring a strong leg so I was satisfied. These were on a converted Chev V-8 914 and either seemed more than adequate. The most important item relates having your braking system in very good shape. In building my 914-Sixer (Carrera everything - late model) I opted to use the 23mm which requires a strong leg. It seems to work very well for me at the time being but as I get older I will look at boosting the brakes via hot rod brake technology. Right now it is what I want. I could have used the 19mm which would match better to the early 911 braking system. Depending on your braking system and its condition, I would use OEM equipment and would be happy with either 17mm or 19mm master cylinders. Steve |
kbrunk1 Master Cylinder 17mm or 19mm Aug 29 2012, 10:32 PM
Valy Both will work but the 19mm requires a stronger le... Aug 29 2012, 11:16 PM
mrbubblehead i really like the "feel" of the 17mm. i ... Aug 29 2012, 11:47 PM
gothspeed
i really like the "feel" of the 17mm. i... Aug 30 2012, 01:50 PM
'73-914kid There have been a lot of complaints of internal pi... Aug 29 2012, 11:53 PM
lonewolfe
There have been a lot of complaints of internal p... Aug 30 2012, 12:04 AM
kbrunk1
There have been a lot of complaints of internal ... Aug 30 2012, 07:19 PM
'73-914kid I ran a 19mm master cylinder with stock brakes for... Aug 30 2012, 12:07 AM
SUNAB914 go 19mm you will like the improvement. Aug 30 2012, 05:58 AM
69telecaster The 19 moves a little more fluid, a must for large... Aug 30 2012, 07:36 AM
Krieger If your calipers are stock keep the correct 17mm m... Aug 30 2012, 09:39 AM
DBCooper
If your calipers are stock keep the correct 17mm ... Aug 30 2012, 10:02 AM
Cap'n Krusty Well, I'm here and I've read the above. O... Aug 30 2012, 10:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 04:34 PM |
