| cal914 |
Aug 29 2012, 03:07 PM
Member ![]() ![]() Group: Members Posts: 321 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
my needle on my speedo wobbles up and down when in use doesn't stay at its correct speed just bounces up and down what causes this
| skaufmann |
Aug 31 2012, 10:41 AM
Blissfully Ignorant ![]() ![]() Group: Members Posts: 103 Joined: 26-May 11 From: San Diego - College Area Member No.: 13,123 Region Association: Southern California |
Some clarification needed.
-What lube should be used? -What ends to lube? At speedo and/or at angle drive? -How hard is it to remove the cable at the speedo? |
| Valy |
Aug 31 2012, 11:01 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Some clarification needed. -What lube should be used? -What ends to lube? At speedo and/or at angle drive? -How hard is it to remove the cable at the speedo? Any oil is fine. Engine oil works well. It's usually the speedo side that gets dry because its higher. You literally pull the speedo and unscrew the cable end with your hand. Some electrical contacts may come loose before you notice so pay attention to the colors and locations. |
cal914 speedo needle Aug 29 2012, 03:07 PM
underthetire Bad cable
loose angle drive Aug 29 2012, 03:40 PM
Valy Lube the cable. If it doesn't help, there is d... Aug 29 2012, 04:11 PM
Elliot Cannon It could be that the cable has broken strands and ... Aug 31 2012, 11:15 AM
zeezee I messed my speedo cable up when yanking on the ga... Aug 31 2012, 10:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 02:05 AM |
