| tornik550 |
Aug 31 2012, 12:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
On my dual weber 44 idf's, I am having fuel dripping out of one of the accelerator pump jets when the car is off. I assume, it is also when the car is running. There is a fairly large amount. It is pretty obvious that it is from the pump jet. I really dont think it is a float height issue cause it is only one jet that is doing this.
The car has been sitting for two weeks due to some electrical issues. The engine was running fine prior to this. Now it is running ok however I am now having a popping noise when I decelerate. It may be present at other times however the car is so loud that I cannot hear it. Ideas? |
| toolguy |
Aug 31 2012, 01:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,277 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
so do you mean it's dripping inside the carb from the accelerator jet nozzle, when you shut if off?? Or is it leaking from the accelerator pump cover on the outside??
If inside, I'm thinking fuel percolation in the float bowl. . look for a link to drilling pressure relief passages in the top plates |
tornik550 Fuel dripping from accelerator pump jet- IDF Aug 31 2012, 12:49 PM
tornik550
so do you mean it's dripping inside the carb ... Aug 31 2012, 02:23 PM
mrbubblehead i think the accelerator pump jet is in the bottom ... Aug 31 2012, 03:26 PM
tornik550
i think the accelerator pump jet is in the bottom... Aug 31 2012, 03:51 PM
mrbubblehead your right, it is a one way valve. and so is the s... Aug 31 2012, 04:07 PM
toolguy the check balls keep fuel from the accelerator pum... Aug 31 2012, 04:46 PM
tornik550
the check balls keep fuel from the accelerator pu... Sep 1 2012, 08:49 AM
toolguy Theoretically, you are correct. . both nozzles sh... Sep 1 2012, 12:50 PM
tornik550 Just another bit of info that I forgot to mention.... Sep 1 2012, 02:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th September 2026 - 10:14 PM |
