> Fuel dripping from accelerator pump jet- IDF
tornik550
post Aug 31 2012, 12:49 PM
On my dual weber 44 idf's, I am having fuel dripping out of one of the accelerator pump jets when the car is off. I assume, it is also when the car is running. There is a fairly large amount. It is pretty obvious that it is from the pump jet. I really dont think it is a float height issue cause it is only one jet that is doing this.
The car has been sitting for two weeks due to some electrical issues. The engine was running fine prior to this. Now it is running ok however I am now having a popping noise when I decelerate. It may be present at other times however the car is so loud that I cannot hear it.
Ideas?
toolguy
post Sep 1 2012, 12:50 PM
Theoretically, you are correct. . both nozzles share 1 common fuel bowl, but 1 must have less resistance to flow than the other. . I'd imagine that if you put your finger over the hole in the nozzle that's dripping, the other one would start dripping. That might be a good test. . .
you'll need to pull up a diagram of your carb and the passages and see what goes where. . and do a web search and see if there is a fix where you drill a relief hole in the top plate. . there is for the Weber 3 barrels. .
- Lo-Fi Version Time is now: 4th September 2026 - 10:14 PM
