| Noodles |
Sep 1 2012, 07:15 PM
Newbie ![]() Group: Members Posts: 37 Joined: 17-July 12 From: Seattle,Wa Member No.: 14,688 Region Association: Pacific Northwest |
OK first off I'm a complete noobie. Have had my teener for about 2 months now so I'm learning everything as I go.
Today I tore off my valve covers because car started running very badly. Had a big miss and lost almost all power. Was adjusting valves starting at 1 and working my way around, had a few that were in need of adjusting then I got to number 4 and found this. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1028.photobucket.com-14688-1346548525.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1028.photobucket.com-14688-1346548525.2.jpg) The nut was sitting in the bottom and the washer is just missing. Ran a magnet around and just no luck finding it. Dont know if its in the bottom end or what. I got some new washers and tightened it down but now it pushes the rocker down to far once its good and tight, (I think thats what its called, like I said I'm very very new) and I cant get a feeler gauge in to adjust the valves, Its pushed way down below the spring and very tight. I can move the far right one but the one on the left wont budge whatsoever. Any help and advice would be much appreciated. Am I going to have to tear this all apart and redo it or am I just missing something easy? |
| Dave_Darling |
Sep 1 2012, 08:29 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
If that cylinder is at TDC, there should be some slack on both arms. Make sure you're at TDC for that cylinder.
The pushrod could have fallen out of the "cup" in the lifter, and be stuck on the lip of the cup. You can fix that with a good bit of messing with the pushrod; I have poked an L-shaped Allen wrench partway down the tube to act as a fulcrum to push the inner end of the pushrod up into the cup. --DD |
Noodles Flying through a Valve adjustment Sep 1 2012, 07:15 PM
bandjoey http://www.914world.com/bbs2/index.php?showtopic=2... Sep 1 2012, 07:20 PM
Noodles
http://www.914world.com/bbs2/index.php?showtopic=... Sep 1 2012, 07:58 PM
Bob L. I'll bet it went down the oil return tube. If ... Sep 1 2012, 07:48 PM
rhcb914 I would take that assembly out and see why you los... Sep 1 2012, 08:27 PM
rick 918-S
If that cylinder is at TDC, there should be some ... Sep 2 2012, 07:19 AM
dirk9141973 I had this problem or about the same
1. Check th... Sep 1 2012, 08:46 PM
dirk9141973
1. Check t... Sep 1 2012, 09:03 PM
brant also when those shafts get loose, the pushrod fall... Sep 2 2012, 12:34 AM
etcmss so where is the washer? can it be affecting prope... Sep 2 2012, 04:39 AM
The Cabinetmaker I don't see how the washer could have made its... Sep 2 2012, 06:55 AM
The Cabinetmaker I don't see how a washer could get past the li... Sep 2 2012, 09:34 AM
euro911 I don't see how a washer could get past the li... Sep 2 2012, 11:31 AM
aircooledtechguy
I don't see how a washer could get past the l... Sep 2 2012, 11:45 AM
Noodles Thanks so much for all the replies, I'll be te... Sep 2 2012, 09:45 AM
cgnj I would check all of of the push rod tubes.I find ... Sep 2 2012, 11:56 AM
aircooledtechguy
I would check all of of the push rod tubes.I find... Sep 2 2012, 09:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th April 2026 - 07:05 AM |
