| Noodles |
Sep 1 2012, 07:15 PM
Newbie ![]() Group: Members Posts: 37 Joined: 17-July 12 From: Seattle,Wa Member No.: 14,688 Region Association: Pacific Northwest |
OK first off I'm a complete noobie. Have had my teener for about 2 months now so I'm learning everything as I go.
Today I tore off my valve covers because car started running very badly. Had a big miss and lost almost all power. Was adjusting valves starting at 1 and working my way around, had a few that were in need of adjusting then I got to number 4 and found this. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1028.photobucket.com-14688-1346548525.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1028.photobucket.com-14688-1346548525.2.jpg) The nut was sitting in the bottom and the washer is just missing. Ran a magnet around and just no luck finding it. Dont know if its in the bottom end or what. I got some new washers and tightened it down but now it pushes the rocker down to far once its good and tight, (I think thats what its called, like I said I'm very very new) and I cant get a feeler gauge in to adjust the valves, Its pushed way down below the spring and very tight. I can move the far right one but the one on the left wont budge whatsoever. Any help and advice would be much appreciated. Am I going to have to tear this all apart and redo it or am I just missing something easy? |
| dirk9141973 |
Sep 1 2012, 08:46 PM
Unregistered |
I had this problem or about the same
1. Check the threads on 6 mm studs replace with 8mm studs 2. When you reseat push rods and rocker arms make sure it seats properly 3. Spend extra time adjusting valves I like the 180 rotation method 1,4,3,2 Once you get it right easy but confusing good luck!! |
Noodles Flying through a Valve adjustment Sep 1 2012, 07:15 PM
bandjoey http://www.914world.com/bbs2/index.php?showtopic=2... Sep 1 2012, 07:20 PM
Noodles
http://www.914world.com/bbs2/index.php?showtopic=... Sep 1 2012, 07:58 PM
Bob L. I'll bet it went down the oil return tube. If ... Sep 1 2012, 07:48 PM
rhcb914 I would take that assembly out and see why you los... Sep 1 2012, 08:27 PM
Dave_Darling If that cylinder is at TDC, there should be some s... Sep 1 2012, 08:29 PM
rick 918-S
If that cylinder is at TDC, there should be some ... Sep 2 2012, 07:19 AM
dirk9141973
1. Check t... Sep 1 2012, 09:03 PM
brant also when those shafts get loose, the pushrod fall... Sep 2 2012, 12:34 AM
etcmss so where is the washer? can it be affecting prope... Sep 2 2012, 04:39 AM
The Cabinetmaker I don't see how the washer could have made its... Sep 2 2012, 06:55 AM
The Cabinetmaker I don't see how a washer could get past the li... Sep 2 2012, 09:34 AM
euro911 I don't see how a washer could get past the li... Sep 2 2012, 11:31 AM
aircooledtechguy
I don't see how a washer could get past the l... Sep 2 2012, 11:45 AM
Noodles Thanks so much for all the replies, I'll be te... Sep 2 2012, 09:45 AM
cgnj I would check all of of the push rod tubes.I find ... Sep 2 2012, 11:56 AM
aircooledtechguy
I would check all of of the push rod tubes.I find... Sep 2 2012, 09:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th April 2026 - 07:05 AM |
