> Flying through a Valve adjustment, and discovered why car was running BAD!!!!
Noodles
post Sep 1 2012, 07:15 PM
OK first off I'm a complete noobie. Have had my teener for about 2 months now so I'm learning everything as I go.
Today I tore off my valve covers because car started running very badly. Had a big miss and lost almost all power. Was adjusting valves starting at 1 and working my way around, had a few that were in need of adjusting then I got to number 4 and found this.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1028.photobucket.com-14688-1346548525.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1028.photobucket.com-14688-1346548525.2.jpg)
The nut was sitting in the bottom and the washer is just missing. Ran a magnet around and just no luck finding it. Dont know if its in the bottom end or what.
I got some new washers and tightened it down but now it pushes the rocker down to far once its good and tight, (I think thats what its called, like I said I'm very very new) and I cant get a feeler gauge in to adjust the valves, Its pushed way down below the spring and very tight. I can move the far right one but the one on the left wont budge whatsoever.
Any help and advice would be much appreciated. Am I going to have to tear this all apart and redo it or am I just missing something easy?
TheCabinetmaker
post Sep 2 2012, 09:34 AM
I drive my car everyday
I don't see how a washer could get past the lifter. Maybe its sitting in the lifter cup causing the problems with the clearance.
Noodles   Flying through a Valve adjustment   Sep 1 2012, 07:15 PM
bandjoey   http://www.914world.com/bbs2/index.php?showtopic=2...   Sep 1 2012, 07:20 PM
Noodles   http://www.914world.com/bbs2/index.php?showtopic=...   Sep 1 2012, 07:58 PM
Bob L.   I'll bet it went down the oil return tube. If ...   Sep 1 2012, 07:48 PM
rhcb914   I would take that assembly out and see why you los...   Sep 1 2012, 08:27 PM
Dave_Darling   If that cylinder is at TDC, there should be some s...   Sep 1 2012, 08:29 PM
rick 918-S   If that cylinder is at TDC, there should be some ...   Sep 2 2012, 07:19 AM
dirk9141973   I had this problem or about the same 1. Check th...   Sep 1 2012, 08:46 PM
dirk9141973   I had this problem or about the same 1. Check t...   Sep 1 2012, 09:03 PM
brant   also when those shafts get loose, the pushrod fall...   Sep 2 2012, 12:34 AM
etcmss   so where is the washer? can it be affecting prope...   Sep 2 2012, 04:39 AM
The Cabinetmaker   I don't see how the washer could have made its...   Sep 2 2012, 06:55 AM
The Cabinetmaker   I don't see how a washer could get past the li...   Sep 2 2012, 09:34 AM
euro911   I don't see how a washer could get past the li...   Sep 2 2012, 11:31 AM
aircooledtechguy   I don't see how a washer could get past the l...   Sep 2 2012, 11:45 AM
Noodles   Thanks so much for all the replies, I'll be te...   Sep 2 2012, 09:45 AM
cgnj   I would check all of of the push rod tubes.I find ...   Sep 2 2012, 11:56 AM
aircooledtechguy   I would check all of of the push rod tubes.I find...   Sep 2 2012, 09:13 PM
- Lo-Fi Version Time is now: 18th April 2026 - 07:05 AM
