| moggy |
Sep 2 2012, 02:20 PM
Member ![]() ![]() Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
My steering wheel has been developing a wobble over the past few years, now it's time to do something about it. I've ruled out the steering wheel itself. The steering wheel wobbles up and down. as if it's loose I've heard there's a bearing that's a common item that causes this, but looking at the Pelican Parts site its not clear to me which one.
http://www.pelicanparts.com/catalog/shopca...r_pg2.htm#item9 The above link shows the following parts: Upper steering column bushing repair sleeve Inner steering shaft bearing Upper steering shaft bearing Lower shaft bearing Steering column split ring bushing Pressure spring in sttering shaft Initially I went in to buy a steering bearing now I'm totally confused (IMG:style_emoticons/default/confused24.gif) what do I need to buy? |
| Brian_Boss |
Sep 2 2012, 04:07 PM
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
Repair bushing replaces the plastic center of the upper bearing which tends to disintegrate before the bearing wears out.
The repair bushing does not work on the 70 - 71 column which uses a different type upper bearing. |
| 914_teener |
Sep 2 2012, 05:02 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Repair bushing replaces the plastic center of the upper bearing which tends to disintegrate before the bearing wears out. The repair bushing does not work on the 70 - 71 column which uses a different type upper bearing. (IMG:style_emoticons/default/agree.gif) Key word there is replaces the cheap plastic bushing in between the column and the bearing. Don't try to fit the two together. The bushinging mikes out about .003 smaller than the inner race. |
moggy Wobbly steering wheel Sep 2 2012, 02:20 PM
scotty b before you buy anything make certain all of your n... Sep 2 2012, 02:47 PM
moggy
before you buy anything make certain all of your ... Sep 2 2012, 03:41 PM
moggy Thanks guys :DRUNK:
I will check that is the is... Sep 3 2012, 12:53 PM
chuckc
My steering wheel has been developing a wobble ov... Sep 7 2012, 06:55 AM
rwilner I used this bushing to repair this exact issue on ... Sep 7 2012, 11:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 12:56 AM |
